hooker 2055's
Old May 21, 2005 | 02:59 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
hooker 2055's
Im looking to buy some headers for my car and ive read that the 2055's are a real good buy. The thing is though that my car is dual cat equiped and i want to keep that set up, so what my question is can you get those headers with a y-pipe for that setup or do you have to have a custom one. If you have to have a custom one, how would i go about doing that?
thanks
Old May 21, 2005 | 08:47 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Hooker’s dual cat setup is part number 2056 but you have to call them to confirm if they still produce them. But if you go with 2055's you will save money cause you have 1 less cat to buy.
Old Jan 5, 2006 | 02:25 AM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Sorry to bring this one back up from the dead, but I was wondering if the actual headers from the 2056's and the 2055's were the same. I made a mistake and ordered the wrong ones. The 2056's come with a Y-pipe for dual cat cars and if they are the same I can hopefully just order the y-pipe straight from hooker. Any ideas? Heres picture of the set up.
Old Jan 5, 2006 | 01:10 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i honestly believe the 2056's are the a.i.r. tube versions of the 2055's.but let me check.............
Eric B
Old Jan 5, 2006 | 01:23 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
well,i've seen wierder stuff online,but the only reference holley gives to part #2056 is for a brake line splitter!these could be older model headers or you could have an outdated part #maybe?
Eric B
Old Jan 5, 2006 | 01:28 PM
91Z28-350's Avatar
2056 is dual cat. I thought they were discontinued by hooker. It's not in their catalogs anymore.
Old Jan 5, 2006 | 01:42 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
when i contacted hooker about just ordering a dual cat y-pipe they said the headers for 2055 and 2056 were different but you should call and make sure..
Old Jan 5, 2006 | 01:47 PM
91Z28-350's Avatar
Do you know if they will fill a 2056 order?
Old Jan 5, 2006 | 04:21 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
not sure i called almost 8months ago so i couldnt tell ya if they still will or not. But seeing the above member has some i think they might.
Old Jan 5, 2006 | 04:34 PM
91Z28-350's Avatar
Ah, silly me. I thought he had 2055s and wanted 2056s.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
