Will a 3" cat fit my exhaust?
Subscribe
May 24, 2005 | 02:13 PM
Probably a very simple question that I may already know the answer to, but my cat is shot and I am thinking of buying Catco's 3" part # CTO-9118. I already had a 3" cat-back exhaust, but stock exhaust manifolds. If I buy the cat will it all fit together properly? Thanks for any help you guys can provide.
Reply 0
May 24, 2005 | 02:15 PM
You should be fine. It would be easier if you had 3" pipe which you do. go for it. OR you can go CATLESS....just a thought
Reply 0
May 24, 2005 | 03:22 PM
Catless until inspection time.
Reply 0
May 24, 2005 | 03:25 PM
I would love to go catless but I don't have access to any welding equipment to weld a straight pipe in and there are NO shops willing to cut a cat out around here. Any other ways around it?
Reply 0
May 24, 2005 | 03:46 PM
It won't fit without modification to the y-pipe at the cat inlet and the cat-back at the cat outlet. Welding required.
Only alternative is a direct-fit cat for LO3 TBI.
Reply 0
May 24, 2005 | 11:36 PM
Are you sure the shops wont do the Catless for you? The shops in Cali will do for me. Huh? Go figure
Reply 0
May 24, 2005 | 11:58 PM
Quote:
Its a federal law and $1500 fine as far as I know. A shop breaking the law like that will really get screwed over.
Reply 0
May 25, 2005 | 09:03 AM
That's what I was afraid of. Would there be any welding/modifications to make if I also put on new headers/y-pipe?
Reply 0
May 25, 2005 | 05:58 PM
If you get emissions-legal headers intended for '86-'90 TPI single cat application, such as Hooker 2055, the 9118 cat will slip onto the y-pipe and you can clamp it together if you like.
That still won't solve your cat-back problem. However, shops aren't bound to not modify anything beyond the cat.
Reply 0
May 25, 2005 | 08:37 PM
That Catco part number was made for a stock application.
Reply 0
May 26, 2005 | 12:52 AM
It really depends on the car, there have been at least 6 different cat setups on the V8 3rd gens, and some years had 2 or 3 possible setups. In most cases on a V8 car you’ll have either a 2.5 or 3” cat, but in some cases it might be flanged or you might have dual cats
Reply 0
Subscribe
