headers
Old Jun 14, 2005 | 09:48 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Transmission: 5 Speed
Axle/Gears: 3:08
headers
I know I probley asked this question before but bare with me! I just want it right. Im getting ready to put a 350 in my 92 rs camaro, 5 speed and Im not sure what what smog headers to put in it. I work nights and alot lot on week ends and dont have much time to research. would they be standard or shorty headers? would headman or edelbrock be better? were's the cheapest place to buy them? thanks for your patience and understanding!
Old Jun 14, 2005 | 12:22 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The shorty headers with a supplied wye pipe (Y pipe) would be the best all around by far. Not an easy install whatever you go with but they will fit up to your factory exhaust. Not cheap for a decent set, Hooker or Edelbrock seem to be the most common and maybe the Edelbrock install a bit easier.
Old Jun 14, 2005 | 11:43 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Not an easy install for some sets... some are cake. My Hedman 68470 shorties were installed inside of 30 minutes. Pass side slid right in w/o even removing the spark plugs, and the drivers side only needed the valve cover removed.
They work GREAT on my 350 as well. 1-5/8" tubes and 3" collectors on that set. Lots more power
Old Jun 15, 2005 | 08:32 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
camaro 92
thanks, I was looking at the 68481 for my 92, not bad with the y pipe, with smog tubes.
Old Jun 15, 2005 | 08:54 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The y-pipe that Hedman makes is an awesome piece, has an adjustable piece on the driver side which lets you get the alignment great and it dumps right where the converter would goto. Word of advise though, if you don't get the coated ones, you might want to get some extremely high heat paint and paint them though because they just have shipping paint on them.
Old Jun 15, 2005 | 09:47 AM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
the motor is not in yet? i would think any of them would b easer than if it was in the car. i just put my 2055's in and i had to unbolt passenger motor mount and jack it up bout an inch to finish the job. wasnt easy
Old Jun 15, 2005 | 10:35 AM
86iroclamarque's Avatar
Car: 1986 IROC
Engine: 305ci DEAD FINALLY! 350 almost ready to go in!
Transmission: 700R4/Coming out TH-350 going in!
Re: camaro 92
How much did those run you? I was just looking at those with Jegs. They do come with A.I.R and the Y right? I gotta be smog legal.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
