Headers on a stroked 406???
Old Jul 25, 2005 | 12:27 AM
slow84ta's Avatar
Car: 84 15th Anniversary Trans Am
Engine: built 406
Axle/Gears: 3.73 10bolt
I think I have my mind set, but I would just like some input from others.
I'm finishing up my stroked 406 that'll be going into my 84 Trans Am(details at my cardomain, check it out)
anyway I got afr 210s, big ports. I need some "big" headers
1 3/4 or 1 7/8 Full tubes prefered
ultimate plan is a pair for super comp hookers that are 1 3/4
anyone know of a good header that maybe 1 7/8 or will the hookers be enough?
I also plan on doing 2 straight pipes back to chambers ending before the rear axle with this setup...
For now untill I get more money I have slp shorties which are 1 3/4 that I picked up cheap.
Old Jul 25, 2005 | 03:52 PM
brutalform's Avatar
Hooker SuperComps #2210. These will be fine for a 406, (BTW, which is a .030 over 400). Exhaust pipes will be an issue though.
Old Jul 25, 2005 | 04:34 PM
slow84ta's Avatar
Engine: built 406
yup .030 over
I'm gonna try and fit a 3 inch x pipe on it.
Old Jul 26, 2005 | 09:42 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I run the Hooker super somps on mine and they should work just fine in your application. I run this car through the pipe and open header, no difference anywhere...that was the same results I had running my Heddman LT's with my old 355, ran the same corked or uncorked, same muffler type.
I've debated H or X pipe since right now I just have the dual pipes coming off the collectors into the m,ufflers dumping before the axle, but after finding the car does'nt mind corked/uncorked, the only advantage I'd see to an H or X pipe is to lower interior noise, no performance gains. Could be wrong on that idea since I have'nt tested it, but as tight as everything is under my car, installing yet another pipe would be a headache to say the least, already hve troubles gettng it on the trailer since it has to slide on the mufflers to get over the beaver tail.
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Night rider327
Sep 16, 2015 02:20 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
