issues with 3 inch catback
Old Aug 24, 2005 | 11:18 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
im dropping my car off tonight to get the exhaust done tommorow. i have a 3 inch, long style dynomax bullet but when i called the place the guy (who comes highly recomended by hotroders and racers alike) said he wasnt sure if he could get the 3 inch tubing up over the rear. i really hope he can because i allready bought the muffler i while back and obviously i want the hi flow pipe.
i thought 3 inch was pretty common? is there a mod you have to do first??
Old Aug 24, 2005 | 11:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you're speaking of the intermediate pipe, the 3 inch will fit. I'm running a Hooker cat-back with no problems.
JamesC
Old Aug 24, 2005 | 11:31 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
uh not sure. i wanted 3 inches from the cat all the way to the muffler and all the way out, over the axle and everything. that work??
Old Aug 24, 2005 | 11:36 AM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I just had my system made and he did a 3in over the axle, tight fit but it will work
Old Aug 24, 2005 | 12:07 PM
JamesC's Avatar
Yep, three inch mandrel bent all the way, though there is a bit of an indentation in the pipe where it goes up over the axel.
JamesC
Old Aug 24, 2005 | 03:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah there are 4inch mufflex systems at go over the rear axle....
my flowmaster setup is 3inch all teh way back and soon to have a dynomax bullet where the 80 series muffler sits
Old Aug 25, 2005 | 11:36 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
cool im good then. this guy is realllly cheap like less then 100 for this setup but its not mandrel bet its somewhat like crush tube but with one steady indent, less intrusive.
Old Aug 25, 2005 | 12:45 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Considering that 3" cat backs came factory on the L98 cars and you can fit a 4" pipe on a lowered car, this guy is being a PITA.
Old Aug 25, 2005 | 01:03 PM
JamesC's Avatar
Just throwing out some info. I once measured the L69 intermediate pipe, the same system used on L98s, I believe, and it was only 2 3/4. Some after market cat-backs, like the Hooker I'm using, do measure 3 inches.
JamesC
Old Aug 25, 2005 | 02:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
my L98 iroc came with 2.5inch piping stock
1984HO
Mar 19, 2021 11:59 AM
Street Lethal
Apr 30, 2019 12:14 PM
Irocguy01
Sep 28, 2015 02:03 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
