3" y pipe in Stock location
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Just like the title says, has anyone ever put a Mandrel bent 3" y pipe that goes in the stock location, my largest concern is that 3" pipe will not fit between the K-member and the oil pan. I did do a search on this and it yeilded nothing so sorry if this has been said before. Thanks for any comments or suggestions. Barry
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I dont think it fits, and I don't see why you'd need it. 2.5 is more than enough for 1/2 of the motor. It all goes into a single 3" pipe anyway.
I'm going to try and pull off a true dual 2.5" setup thru the factory routing like Willie did. http://members.optushome.com.au/iroc...st/exhaust.htm
You dont see why you need it? More exhaust out=More hp, and what i have sounds like crap, dont want duals because they look like crap.
Car: 1991 Camaro Z28
Is your 350 pretty modded? Because if it is anywhere close to stock within 50-100hp I am with jimp2001 and say you don't need it. escpecially if it is (2) 2.5's dumping into a 3" I don't think it matters at all.
My motor is a mild 350 with a 150 shot of gas, The 3" y-pipe will end where the CAT was and there will be a Bullet muffler, and that is it
Car: Z/28
Engine: 355
Transmission: Turbo 400
you looking for something like this then. This is a 2-1/2 inch Y-pipe. You can see how much it hangs below the K member. A 3.0 inch would be real close to the ground and will probably hit and get damaged. This is more than enough for your setup. And its EXTREMELY LOUD! Like open headers.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Car: Z/28
Engine: 355
Track only and at one race I was asked to leave because I didn't make the 95 db level at 50 feet! SCCA sure sucks on their sound requirments
Originally posted by firebirdjosh
What does that even mean. Do a half assed job on any install and it looks like crap. Unless you're talking about the tips which would be similar to what our cars have stock.
And I already have a 2 1/2" Y pipe on my car with a Bullet, i just want a 3", 2 1/2" tucks underneath the car great and just like the factory, here is a pic of my car, it just kind of give you an idea, wish i had a better pic though
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
i can barrely get in and out of my driveway with my TD's.. but that's the long tubes fault..
Originally posted by weberflorida
LOL!! Nice. So is your suspension pretty modded also? Do you have a webpage for your car?
Just wanting to check out what you have done to it.
Bill
Bill
Car: Z/28
Engine: 355
Weber
Save yourself alot of grief. set your car up for drag racing like I should have done! Car does handle good tho in autocross form.
better ,nicer group of people in drag racing and no hassles with rule changes year to year trying to keep up with the mports.SCCA loves imports and just hates F-bodies.
Yeah right on. I am not wanting to setup my car for dedicated racing. I am going to drive it on the street as well, but would like to dibble dabble in drag and autocross.
Got any good suggesstions.
Car: Z/28
Engine: 355
Yes. Pick one or the other. You can't successfully be fast setup for both. Go to QualComm stadium and check out their dragstrip and autocross events. ask lots of questions and decide what you want to do.
_____________________Straight!
Transmission: 4L80E/4L80E
Bigger isn't always better. It may actually hurt performance. Most likely not, but 3" simply isn't necessary in your case, and won't fit between the crossmember and oil pan without hanging down in any case.
Can we assume you have headers? If not, then this whole discussion is nothing more than McDonalds parking lot BS.
Thank you Five7Kid for answering my question, because i know a 2 1/2" y will fit because i have one, but second of course i have headers,
Had to ask. Many, many times on this Board, we've assumed post after post that someone had some particular upgrade because of the other things they were asking about, only to find out that wasn't the case.
No problem, i understand, but thanks for the straight answer!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 3" y pipe in Stock location
This winter I will upgrade to a 2.50" setup for sure. 3" is just too big. It would be ideal of course, because you want to get the gasses out of the header and expanding as quick as possible. But still, as others have suggested, it can be considered overkill..
BTW my car is an 11 second car in street trim (tires), and 10 second capable with slicks. (but I'm sure the drivetrain would explode).
-- Joe
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
transaero
Aug 31, 2015 01:14 AM
