What To Do...
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
What To Do...
...county started emissions. Prior to them starting this, I did all kinda upgrades to my car, one of which included the exhaust system - which included, new headers w/o air tubes, no air pump and no cat. I went over 5,000 miles this year (whoops), so I'm not going to be able to get exempt from emissions. All this work is probably gonna be around $2,000 for stock-like parts, and not performance parts, which are on it now.
I love my car... but I don't have the $2,000 to fix it...
[/rant]
[/rant]
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Cat costs $50. Try one and see if you pass. I passed emissions without AIR. Most people won't know you're missing anything as far as what the car came with stock. That's what happens when you pollute wrecklessly
. Supreme Member
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
buy stock parts used, they're real cheap. Most people will just give them to you. Or try a junkyard. It won't cost anywhere NEAR 2k to do it, if you do some work yourself.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do they have a visual inspection or only the sniffer? If they only have the sniffer I would spend the $50 on a high flow cat and put it in place. That could cost you another $30+ in labor if you can't do it yourself. None the less, if your motor is fairly stock you should pass with nothing more than that.
Car: '72 Chevy Nova
Transmission: TH350
benoit454
Jan 28, 2004 06:05 PM
