oxygen sensor wire
Old Sep 15, 2005 | 03:23 PM
NathanC5's Avatar
Car: 84 camaro z28
Engine: '89 L98 converted to CC Quadrajet
Transmission: '89 700-R4
oxygen sensor wire
what is the wire coming from the oxygen sensor supposed to be hooked up to? i have an 84 camaro that has a ccc carb. the wire is just there with the end just sitting on something
Old Sep 15, 2005 | 05:46 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
there should be a matching connector with the same color wire running across the front of the engine. if you have the original looms, it should be in th AC wire loom. thats stock location though. the wire will originate from the firewall on the passenger side of the engine, and probably blend in with GM's rat's nest.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Bert87
Aug 23, 2015 03:50 PM
beast94
Aug 20, 2015 06:44 AM
