dumped or back in the bumper
Old Sep 18, 2005 | 09:34 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
im getting a single exhaust with spintech pro street muffler but im not sure what i should do ? should i dump it with a turndown or should i have a single tailpipe exiting out the back? which is better?
Old Sep 20, 2005 | 08:47 PM
87_350's Avatar
Car: 87 firebird formula
Engine: 350 sbc
I think it all depends on what you prefer
Old Sep 20, 2005 | 10:40 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
is it possible to have a spintech pro street or pro shoot out with two tailpipes instead of one?
Old Sep 21, 2005 | 09:18 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Since your going with the single exit I would say tuck it up high and have it dump behind the bumper. If you can get it just right you won't be able to see the tail pipe and it will look clean. That's what I did with mine and nobody has any idea what I have up in there until they get under the car. That's my .02 though.
Old Sep 21, 2005 | 09:51 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
But don't you get exhaust gases into the car when sitting still (like at a stop light) that way?
Old Sep 21, 2005 | 04:57 PM
CraZ-28's Avatar
Car: 1991 Z-28
Nope. Also, after reading again my statement is not true. I'm not using a "dump pipe" but more like a huge stock type tail pipe. What we did was make the pipe flush with the bumper in the stock location. If you get down you can see that it sits just below but like maybe a 1/4 of an inch. I never smell exhaust with the way it's setup. Having done this, with the car running in the dirt you can see the exhaust hitting the ground about 1 to 1.5 feet behind the car. I'll see if i can find a pic to show.
Old Sep 21, 2005 | 05:03 PM
CraZ-28's Avatar
Car: 1991 Z-28
Ok, here is one that I found and I drew on the pic to give an idea of how it's setup. Hope that helps.....
Old Sep 21, 2005 | 05:53 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
thats what i want a hidden single tailpipe . who ever has a single hidden tailpipe post the pics up.
Old Sep 22, 2005 | 08:38 AM
CraZ-28's Avatar
Car: 1991 Z-28
I just did. If I can remember, I'll see if I can locate some of the pics I have that show it under the bumper to give you an idea.
Old Sep 22, 2005 | 09:10 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
mufflex-performance.com should have what you need. You can also ckeck my web site on page 4 for more pics.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
