hooker 2055 setup roblem
Old Sep 21, 2005 | 12:46 AM
AC398's Avatar
Car: Red 89 GTA
i jusdt got my new hooker shorties the 2055s and i was mocking them up to see how theyd fit and i noticed that the collecetor (at least i think its the collector its where the 4 tubes come into 1) doesnt fit all the way into the y pipe. the end of the collector looks like a ball and the y pipe doesnt slip over it and only about 1/2 inch of the ball at the end of the collector goes into the y pipe. is this right because when i put the screws in where the y pipe and collector meet there is about a 1/2 inch gap between the 2 flanges(see picture), shouldnt the 2 flanges be touching and u shouldnt be able to see the bolt in between them? im sure they are the right headers because the y pipe and header both say 2055 on them i just want to know if the headers and y pipe should fit like this or maybe they sent me the wrong y pipe or header?
Old Sep 21, 2005 | 06:40 AM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
There should be a gap, tighten each side like one turn at a time so they pressure is even. They dont fit inside each other with the flanges flush.
Old Sep 21, 2005 | 01:32 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
yeah the flanges are not supposed to touch... its a ball socket.. not a "plate to plate" type. the kind you have seen on other headers are just a flat triangle and both meet.. these are not them
Old Sep 21, 2005 | 04:13 PM
AC398's Avatar
Car: Red 89 GTA
thanks, i was kinda worried there was a problem with the headers but its all good, does anyone know the legnth of a stock catalytic converter, because im setting to go and make my own straighe pipe??
Old Sep 21, 2005 | 06:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depending upon how you connect it at the I-pipe and how much you expand to fit over the y-pipe, it's about 21".
Old Sep 21, 2005 | 06:23 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
it's about 21".
I just measured my converter and its around 21 inches as well
Old Sep 21, 2005 | 07:49 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Im doing the same thing in auto shop tomorrow, I will let you know it went and how much pipe it actually took me.
Old Sep 22, 2005 | 03:10 PM
five7kid's Avatar
This thread has a few references to my 2055's. https://www.thirdgen.org/techbb2/sho...56#post2459856
Old Sep 22, 2005 | 03:22 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
I did this today. I used a 24" pipe that was 2 1/4 on one end and 2 1/2 on the other and a adapter pie that was 2" diam and about 3" long. I slid the 2 1/2 side over the Y pipe end. On the exhuast pipe side I slid the 2" tube into the exhaust pipe and into the 24" pipe. I used U bolts to secure all parts and bent the stock hanger a bit to hold it all up. Make sure that you have enough clearence between the exhaust pipe and the drive shaft at the rear of the car, thats the oly spot thats close.
Old Sep 22, 2005 | 03:26 PM
five7kid's Avatar
Mine.
I had expanded the I-pipe for a slip fit previously.
Old Sep 23, 2005 | 12:42 PM
AC398's Avatar
Car: Red 89 GTA
thanks for the help cuz im welding an exhaust cut out to the end of my y pipe and then a steel tube from that to my exhaust
Pac J
May 17, 2020 10:44 AM
2012sergen11
Oct 13, 2015 07:38 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
tattmann
Sep 27, 2015 05:20 PM
