flowtech performance that worst?
hi,
iv seen flowtech for salefor very cheap vey close to me (im from canada) and im wondering if they are that worst performance wise .. i will build my exaust myself so i don't care about that crapy y pipe evryone talk about but i wonder if they really flow that bad .. normaly i would pay more to get good quality one but with shiping and everyting i will save like 150$-200$ comparaid to a pair of hooker or headman but i don't want to lose power !
engine will be a 350 with 1968 big valve unknow casting head OR vortec with a 6500rpm cam/intake .. i want to maximise performance @ ~6200-6500 rpm
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
As long as it's a full 3" system, I'd say go for it if you are really looking to save some money.
There are certain qualities in an exhaust system that justify the extra money you pay for them. Stainless steel and mandrel bending come to mind, among other things.
Transmission: 4L80E/4L80E
The 1-1/2" primaries are performance killers above 5000 RPMs for a 350.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
flowtech is probably the worst performance brand you can buy, only slightly better than stock parts, imo.
Just save up a couple bucks and buy some real parts. You'll be WAY happier.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i have to agree, the flowtechs arent that great. i work at an auto parts store and we stock this crap.. they are about an avg of 200 dollars cheaper then any other header per application, the reason? small tubes, painted black. and poor machining at the flange. these will rust real quick on ya (within a year) and no explanation needed for the smallest tubes ever used for a header.
this restriction alone is great for torque, but then again your manifolds do that just as well.
Originally posted by rx7speed
off topic question.
why old 1960's heads?
off topic question.
http://www.mortec.com/castnum.htm say : 3973370....69-70...350..........over the counter in US, Canadian 350/300hp production use in Pontiac, 64cc, straight or angle plug
and for the header i will definetly wait .. they guy say they where 1 5/8 but if the are 1 1/2 i don't want them ..
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
According to my Summit catalog, some Flowtech are 1 1/2 and some are 1 5/8 in a 2 1/2 collector. Some are even ceramic coated. I compare them to Pacesetter hedders...
As for rust, I am currently running 1 3/4 Slp hedders and they rusted in less than a year!!!
Flowtech are not the best but better than stock manifolds for sure. They will outflow them and if you are planning in a custom 3" as I did, you will save some $$$ if you are short. But I agree that you could save more and buy ceramic Hooker or SLP.
Like I said in another posting, SLP are stainless steel but cheap casting wich is probably recycled steel
I was very fustrated with them, paying 850.00$ CAD back then!!!
When I went back to my local SLP dealer in Montreal (Zeke's Automotive), the technician said they are a mixed casting wich is not all stainless? That is probably why SLP are only selling Ceramic coated headers
Again, not everyone can/want to afford expensive exhaust parts. I recall when I was younger and owned my first 88 camaro (back in 92), I wanted to modify the way I modified mine these days, but just couldn't afford more than Dynomax Superturbo and Flowtech painted headers...
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Actually, not all flowtech headers are that bad..... just the ones for our cars. The guy who is rebuilding my tranny showed me a set he bought for his truck and I couldn't believe they were Flowtechs..... the flanges were thicker than my 2055s, but other than that, they looked just like the Hookers. The biggest reason I didn't like my Flowtechs was the crappy thin collector flanges would just bend when you tighten them.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have nothing but terrible things to say about flowtechs. I would run stock manifolds again before I ever put a set of these headers on an F-body again.
Refer to this post for more info.
My experience with Flowtech Headers
Why companies cheaped out on products for our cars, who knows.
Car: 91Z28 L98
Engine: HSR 350
5-7, those may be the same ones I saw. Yesterday I took my 2055s over when I picked up my tranny and compared them to those Flowtech truck headers, and they were very similar in quality, but the flowtechs actually had thicker flanges.... 1/2" compared to my 2055s 3/8".
But just to reiterate.... the F-body flowtechs have paper thin flanges... I don't want to confuse anybody into buying any fbody flowtechs and expect them to be good quality. But I did run flowtechs on my last Iroc and they weren't THAT bad, they just weren't good. Hard to get the collector flanges to seal.
Originally posted by five7kid
Same can be said for Pacesetter. My brother has a set on his '93 pickup, good quality, fit great, aren't rusting through.
pacesetter isn't just cheap on the f-bodies.
the rx7's have problems with them if I remember right honda people like don't them the supra ppl hate them.
most everyone I hear about doens't like pacesetter unless they are the only option available
Pac J
May 17, 2020 10:44 AM
