Connecting Coated Y pipe to Cat
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Should a clamp be used @ this juncture?
or...
If it is welded, the ceramic coating will need to be removed & possibly (in the future) weaken the y pipe..??
Rafael
or...
Rafael
Transmission: 4L80E/4L80E
Hey, the part that's clamped looks exactly like the part of the cat that was clamped to the y-pipe before it was coated.
Honest!
Honest!
Ok, I guess I'll use a clamp for the cat / y pipe & have the rest welded (since it's not steel)...
Thanks for your pic & suggetions.
Rafael
Rafael
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Nothing wrong with clamps... they work just fine if you know what you are doing.
If you use clamps though, I'd do a small spot weld on either side of the pipe, just incase.
The point was to avoid the welding....
Jet Hot covers their product for life... unless I weld it & the metal breaks where the coating was removed for the weld...
I'll use 1 clamp and have the rest welded... I can check, tighten & replace the clamp if need be.
Rafael
Rafael
Band clamp maybe? I doubt that would hurt the coating, and it should seal it up pretty nice.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
