dented pipe!
Old Oct 13, 2005 | 08:39 PM
SeawolfX13's Avatar
Car: 1990 Iroc-Z
Engine: 5.0 305
Transmission: 700-R4
dented pipe!
I was under my car today, 1990 Iroc-z28, and i realized that the exhaust pipe that seems to be coming down from the engine block which then leads into the Muffler\Cat converter *not sure which, dont know alot about exhaust system* which then leads to tail pipe is dented, its dented right after it bends around the oil pan and continues down the right side of the body, it looks like someone tried to use it as a jack point >_< and ideas on a possible fix, it looks as if its dented about a 1/4 to 1/2 way in... can provide pictures soon if it will help
Old Oct 13, 2005 | 08:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Replace the pipe.
Old Oct 14, 2005 | 09:01 PM
SeawolfX13's Avatar
Car: 1990 Iroc-Z
Engine: 5.0 305
Well, is this affecting my performance? it would at least a little bit because its constricting flow right?
Old Oct 14, 2005 | 10:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stock exhaust is restrictive enough and a dented pipe certainly isn't helping matters.
Old Oct 16, 2005 | 01:34 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
I think your talking about the crossover(?) pipe that leads from the drivers side header to the Y pipe... This is a restriction without a dent... so yeah its affecting your performance.
Get an edelbrock tes headers/y pipe...
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
