N10 Flow
Old Oct 20, 2005 | 11:38 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
N10 Flow
Still have questions about the N10 dual cats. Does the dual cat setup flow any better?
How well does the aftermarket/stock dual cat setup have the ability to flow. Catco makes a dual cat setup but only has 2.5" exit tubing. What have people been doing with the dual cats, ditching them, upgrades, etc. It's bothering me and I need to know.
Old Oct 21, 2005 | 03:44 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Any info?
Old Oct 21, 2005 | 09:45 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm running the dual cat setup. It is with 2 1/2" pipes that currently Y into a 3" pipe. Here in Southern California most that I know are going to the dual cat setup for the better flow.
By the way I will be changing the dual 2 1/2" pipes into a 3" pipe to the Mufflex system with dual 2 1/2" pipes into a 3 1/2 inch pipe.
Old Oct 22, 2005 | 03:22 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Thanks, anyone else?
Old Oct 22, 2005 | 07:25 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I don't see how much of a restriction you can be avoiding. With a quality high-flow 3" cat instead of a 3" pipe, someone lost only like 1HP and a few (like less than a handful) ft-lbs of torque. One 3" cat means you're only replacing one when it goes out instead of 2, and it opens up your choice of headers/exhaust a bit, depending on which manufacturers make kits for the 1-cat/2-cat cars.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
