Is 4 inch to big????
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Ok I have been set on four inch muflex exhuast for a little while and now I am starting to have second thoughts.
What I have right now
406
TPIS big mouth intake
zz9 cam
stock heads
hooker shorty headers
425 hp and 480 ftlbs of torque at the crank.
Plus I am adding a 125 shot
I am finnishing the car but future plans call for
ported 210 cc iron heads
TPIS Mini ram intake
zzx cam.
I dont want to buy exhaust twice. So is four inch to big?
Right now the stock hooker y pipe goes to 3 inch but that will be modified so both pipes meet into 4 inch at the y.
406
zz9 cam
stock heads
zzx cam.
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
If it's a single 4" I don't think that would be a problem pending on whether your getting those extra parts or not.
Car: 91 RS
Engine: 305 Tbi (L03)
The most most imporatant part of the exhaust is the headers themselfs. 4 inch (especially if duals) is plenty. You might see a slight difference by going to a smaller pipe, but you may not even feel it on the butt dyno.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I was thinking that 3.5 would be adiquite. Let me add that my y pipe is 2 1/2 pipes comeing from the header and going to y into 4 inch pipe or 3.5 depending on exhaust.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Check out this chart from Dynomax. I bought the 3 1/2 inch Mufflex system and I'm waiting to have it installed. Anyways going by the chart your engine will do best with a 4" single exhaust.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Thanks thats what I think I will order. I want to have 4 inch anyways. I wounder how loud it will be. I wish I could keep my car some what quiet.
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i have the 4 inch kit with the spintec muffler with dual outs.... and LOVE it... it sounds great at idle cammin and when u get on it DANG u will love it...
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Compared to other exhaust you have heard is it loud. I really dont want loud exhaust. I want as much flow as I can get with as minimal noise.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
MAN same here. I know my car is gonna be loud but I want it to be sorat take cuz I have such a crazy cam.
I guess you can allways add a 4" race muffler right after the Y pipe or something to quiet it down if need be.
When you guys say, go 4" all the way, are you talking aobut the 4" with the mufflex Y-pipe?
I am in desperate need of an exhaust. I have been on the line of making one or just buying the mufflex stuff. And going back to stock ride hight.
Sux cuz I allready have sportline in there.
Maybe I can add weight jacks...........
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I will be going 4 inch all the way back. I am taking the hooker y pipe and cutting off the 3 inch pipe at the y and using 4 inch from then on.
Engine: LS3
hmmm....interesting take on the idea. If you order all the mufflex stuff that is 4" (y pipe and catback) cost around 985. ouch! There has gotta be a better way.
292.50- Y pipe with 02 bungs.
693.00- 4" catback with spintech muffler and dual 4" avalised tips.
I can weld and cut but don't really feel like starting from scratch. No one else makes anything like mufflex right?
I also don't even know if it will fit on my car. I have a spohn adj. TQ arm. UGH these pipes are giving me a head ache!!!!!!!!!!!!
Car: 88 Trans Am
well i dont know how loud it is on the outside i dont let anyone drive my car
soooo... but inside i love it doesnt vibrate like the flowmasters... but yea its loud... but any fast car with a big cam should be right? and i just have a 4 inch catback with no cat and hooker 2055's
soooo... but inside i love it doesnt vibrate like the flowmasters... but yea its loud... but any fast car with a big cam should be right? and i just have a 4 inch catback with no cat and hooker 2055's Thread Starter
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Originally posted by dennisbernal91z
and that will run you what? (($$$))
Car: 88 Trans Am
hey grover.. just my .02 but install the exhaust first... when i had my I pipe off... it ran like **** there wasnt any back pressure.. now i dont know what headers u are running but i have the 2055's with the stock y-pipe and its fine with the 3 inch y-pipe trust me... plenty of c5's on the highway will tell u
... try it before u go and cut up the y-pipe i yould hate for u to do it and it not fit or come out like u would like it... ya know what i mean....
... try it before u go and cut up the y-pipe i yould hate for u to do it and it not fit or come out like u would like it... ya know what i mean.... Thread Starter
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I am not going to cut it all up. I am just modifying where the two pipes meet. I am going to cut the vary end off and modify a 4 inch pipe to it. Cause it really does not make sense to have 4 inch bolt up to a 3 inch pipe cause the restriction is aready there. I know this exhaust is alittle big for me but after talking to a couple of my motor building buddies they recomend I go with the 4 inch.
Car: 88 Trans Am
yea everyone told me it was to big also and i was like screw what everybody thinks.. because u can expand with that big of an exhaust
like mabye turbos... the duramax guys have 5 inch... and i got 4 and dont need a turbo right now
tee hee... its just a good flowing exhaust with enough back pressure and u will love the sound i will see if i can get a vid of my car on here idling... mabye tomarrow
tee hee... its just a good flowing exhaust with enough back pressure and u will love the sound i will see if i can get a vid of my car on here idling... mabye tomarrow Supreme Member
Car: 1989 GTA
Engine: 369 TPI
I just had the Mufflex 3.5" system installed with the Magnaflow 12909 muffler. The Magnaflow muffler is of the straight through design so will have little if any backpressure. The pleasant thing is the muffler is pretty quiet. So I get the performance without the noise.
Engine: LS3
me too.....Too bad it is not the easiest or cheapest set up to make. I am gonna make it simple (bullets) then add inserts untill it is quiet enough. (Dual 3")
Check out this article by David Vizard. Alot of questions can be answered from it.
http://superchevy.com/technical/engi...t/0505phr_exh/
I have the Mufflex Y pipe and single 4" exhaust on my 83 TA. No CAT. Hooker Supercomp 1 3/4" long tube headers.
Just installed a 383 in the car. Haven't got to the chassis dyno yet but planning on it soon. Motor should make ~450FWHP + 150 Shot. But who knows???
I really like the fit and the sound of the system. And it really appears to flow well. My calculations indicate it should flow better than a dual 2.5" system. We'll see.
Engine: LS3
Awsome. Let us know the results. I have a similar motor. And am still on the wall about pipes. I was about to order pipes to make a dual 3".
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Go with the 4" Mufflex you will be happy you did! I know it's pricey, but you get what you pay for and the quality of work is top notch. My car sounds great and the performance is outstanding. For your set up this would be a perfect way to top it off.
amargari
Nov 10, 2015 02:09 PM
redformula88
Oct 14, 2015 06:08 PM
gta892000
Sep 16, 2015 12:37 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
