current popular header gaskets of choice ???
Old Oct 30, 2005 | 12:34 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Gotta replace the header gasskets. Blew out the gasket on rear passenger (#8)-- not sure if the bolt backed out and it blew out the gasket, or if the other way around. Have Hooker Super Comp 2055's. Street-- some strip use.
What is the current popular header gaskets of choice ???
I did a search and read a bunch of posts about it, but still not sure if Iwas able to come to a decision about which is the better/best gasket to use.
I do not mind paying a little extra for a quality product, but I am not into using something just because it's new/different. I will, if it does what it is supposed to do and worth the extra money.
Since both headers need repainted, I was going to pull both -- repaint and get some new regular ARP header bolts for reinstall.
Thanks for any help/advice!
Craig
Old Oct 30, 2005 | 05:50 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I like SCE copper gaskets. Make sure you trim them to match the ports. A thin layer of high temp RTV on both side. They never blow out, last pair you'll ever buy.
Old Oct 31, 2005 | 04:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Percy's dead soft aluminum gaskets are also a good choice. They are great for headers that may have a slightly warped flange.
Old Oct 31, 2005 | 05:11 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Yeah, I have heard good things from several people about the Persy's alum header gaskets.
Thanks for the info guys--Appreciate it!
Old Oct 31, 2005 | 05:25 PM
Dialed_In's Avatar
They're nice, but they will blow out b/c of the layers. They will make up for a warped flange.
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
