Primary tube formula
Old Oct 31, 2005 | 04:26 PM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
Surely someone has a formula for finding the optimum header primary tube size. I'm not finding it.
Old Nov 1, 2005 | 03:46 PM
Car: 85 Berlinetta
OK then, how about a general rule of thumb? How much power can be supported by 1-3/4" primary long tubes? How much can be supported by 1-7/8" primaries? We're not talking about a typical street car here.
Old Nov 1, 2005 | 08:32 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
99% of smallblocks use 1 5/8 headers because they increase torque over 1 3/4 headers.
The 1 3/4 will give you some extra hp at the cost of torque but not enough to make a difference.
1 7/8 are for bigblocks.
Old Nov 1, 2005 | 10:15 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Nononono... HOT (race motors) small blocks can fully utilize 1 7/8 primaries stepped into 2" primaries into 4 or 5 inch collectors. (Stahl headers, Lemons headers, hooker 2322)
400-550 horsepower small blocks 383+ can generally utilize 1 3/4 headers (such as hooker 2210's).
1 5/8 will support more than you think, and almost anything on the street.
HOWEVER, the rules change when you use power adders. Hooker 1 3/4 longtubes will cost you a bit of power if you are supercharging/nitrousing past about 600 horses. Take a look at the Devilray corvette, 600 horsepower N/A with 1 7/8 primaries.
This is a general idea of where things stand, I know someone will post, "I've seen a guy run 9's with 1 5/8 headers." I've seen it too, but how much faster would he have run with a less restrictive header?
Old Nov 2, 2005 | 12:37 PM
Car: 85 Berlinetta
That's the type of answer I'm looking for. My heads were flowed with a 1-7/8" pipe, but fitting a pair of those on a thirdgen would be costly. My 406 has the best of everything and it's borderline whether to use 1-3/4" or 1-7/8" primaries. 2" primaries are not needed for my application and would kill bottom end too much.
Old Nov 2, 2005 | 12:43 PM
Car: 85 Berlinetta
What a dumba$$! I can't believe I just did that! Sorry.
z 28 jari
Sep 14, 2021 10:03 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
83RDRACR
Mar 26, 2016 08:13 PM
redformula88
Oct 14, 2015 06:08 PM
75bike
Sep 20, 2015 09:37 PM
