Which AeroChamber? also header question
Old Jan 2, 2006 | 03:46 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
changing the muffler on my car, since its no longer a daily driver, so no more trying to hang under the radar with my super turbo.
so heres the question to you guys
which aerochamber
right now i have a Big *** 3 inch in 3 inch out super turbo body has to be atleast 20 inches. offset in and out
keep in mind the tip will stay tucked where you cant see it
should i get the
HOK-21505HKR 14 inch body offset inlet centered outlet(because my inlet is offset on my current muffler)
HOK-21506HKR 14 inch body Centered inlet and outlet (better flow? sound?)
HOK-21512HKR 18 inch body offset inlet and offset outlet (seems like the best replacement because of size. but compromizing flow with offset in and out and sound? or larger size better flow?)
also i plan on getting a set of headers and y pipe hedman seems to be the best for the money i currently have the hooker 2550's? (the one without the y pipe) wiht a custom pipe thats garbage and they are old and rusty need new ones.
are jeg's part number 500-68478 the set that you can cut the y pipe and make it 3 inch? which many people are running on here?
1-5/8'' Tubes, 3'' Collector
thanks for the help guys
Old Jan 4, 2006 | 11:39 AM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
no thoughts??
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
