Headers and Angle Plug Heads
Old Jan 5, 2006 | 11:44 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Has anyone had any luck with headers and angle plug heads? I have slp 1 5/8 headers and trick flow angle plug heads and the #8 spark plug boot touches the #6 down tube. I tried wrapping the down tube and using a stainless steal sheild boot, but it still melts. Any suggestions? I'm using 90 degree boots and they work the best.
Thanks,
Jim
Old Jan 5, 2006 | 03:32 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I have no problems with my 1 3/4 SLP's. If you haven't already, you might want to maybe check into getting some shorty plugs. One thing also to remember, there is a difference "Angle plug" heads and "L98 Angle" heads. That could be the reason why I'm not burning my wires and you are.
Hope that helps
Old Jan 5, 2006 | 03:59 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I use the TF heads and slp 1 3/4. They are VERY close on number 8 plug but I have about 1/16 clearance lol. I am running autolites
Old Jan 5, 2006 | 04:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
BTW I am running spiral pro's but on number 8 I have to use a distributor boot on my plug to clear ,as the larger Spiral Pro Boots rest on the tube. Its something to think about.
Old Jan 6, 2006 | 11:28 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Mkos,
I know are set-ups are very simular. Are you running the angle plug heads? I have Accel short plugs in there now and the corner of now three sets of 90 degree boots melts eventaully causeing a spark to show.
Old Jan 6, 2006 | 05:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yes. I have the TF angeled heads. I am running autolites and when I used the spiral pro boot, it burned and I saw a spark in the night lol. I switched to a thin boot that is suppose to be used for the distributor part and now i have about a 1/16 clearance. If need be I have even seen people use a pipe and put a small dent into the primary. Minimal one but just enough that it doesnt touch or hinder performance.
Old Jan 7, 2006 | 05:05 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Cut and weld the offending tube as done in the above posting!
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
