Edelbrock header install problem
Old Jan 6, 2006 | 12:52 PM
aroc's Avatar
I an installing Edelbrock headers on a 1992 camaro with a 305. Instructions say to disconnect steering column connector and slip tube down to steering box. I assume the column connector is the piece about 8" down the column from the firewall with a plastic protector around the lower part and some rubber on the bottom. I took out the bolt but nothing slips apart. I tapped on it a little but it did not want to move much. Am I in the right place.? How do I get it to slip down?
Old Jan 6, 2006 | 02:08 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I have set of 'Brock headers on my car. I took a FEW bolts out of my steering colunm and nothing moved. Obviously I wasn't doing something right. Still with column in place, I managed to squeeze it down thru the top with much prodding. The passenger side was more work, had to remove all the AC stuff. Yeah, I scratched the collectors a bit, but none of said flaws can be seen from the engine bay.
Buena Suerte........
Eric
Old Jan 6, 2006 | 08:45 PM
aroc's Avatar
Got it apart with a lot of gentle tapping with a hammer.
Old Jan 7, 2006 | 05:32 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
whats the deal guys? I did not have to do this when I installed mine. are your motor mounts old and sagging?
Old Jan 7, 2006 | 06:50 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
My motor mounts are fine. Maybe they just made the cars smaller in 89..........
Old Jan 10, 2006 | 05:19 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
When I installed the headers on my 83 I just slipped the drivers side one in. I had to take off my valve cover, spark plugs, and move some hoses and stuff out of the way but I got the header on. Im not sure how to disconnect the connector. I tried to take it apart too but I couldnt get it to budge so I just left it alone before I messed something up lol
Old Jan 11, 2006 | 07:31 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
had to take the steering shaft out on my son's 91 RS when we put edelbrock TES headers on it. we had the valve cover off as we were installing some newly painted ones but still had to remove that piece of steering shaft. These headers were for a TPI engine but we put them on a TBI engine. Maybe some part number headers are slightly different. Of course we also installed a TPI cat. and a TPI flowmaster exhaust system so that will be ready for the TPI engine when we get around to it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
drathaar907
Aug 6, 2015 04:20 PM
