Which length header bolts?
Old Jan 14, 2006 | 08:20 PM
RagTopIROC's Avatar
Car: Black '89 IROC Convertible
Transmission: 700-R4
Ordering Hooker 2055's from Jet-Hot. Want to get Stage 8 locking header bolts. Saw a set on Summit (Stainless Steel) with an underhead length of 1", also with external hex head (set of 12). Will these work for my application? I have a 305 TPI. Or do I need to get the shorter 3/4" inch verson? Also, which head style would anyone suggest? Need to get those babys tight. Thanks in advance!
Old Jan 16, 2006 | 01:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 3/4" will probably work, but I'd go with the 1" if possible.
Only issue I've seen is with my World heads. The 1" punched out the back of one hole allowing a coolant leak. Pretty rare thing, though, and I doubt you'll have a problem with stock heads. I've used 1" on several others and haven't had a problem.
midge54
Dec 27, 2019 04:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
