will t5 & flowtech headers fit ?
Old Feb 3, 2006 | 05:56 PM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
i tried a search before i posted but did not find anything ...
i'm getting a set of flowtech headers, right now i have the 700r4 installed on the car, i would imagine not having to much trouble getting it in but i am higly considering swaping a t5 in there and i wuz wondering if anyone was this setup or knows what sort of problems i might incounter ...i have an lo3 by the way
Old Feb 4, 2006 | 10:02 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes they will fit but I highly suggest you choose another set of headers. IMHO the only thing flowtechs have going for them is their fit. Everything else is garbage.
Old Feb 4, 2006 | 06:24 PM
tsibouky's Avatar
Transmission: t-5
i know i've herd nothing but bad things about them ...
but i figure, there cheap ( budget build ) i will not winter drive it
and they are far more superior then the stock manifolds
so in the end, for the price there good, ps i dont live in the states
and a pair of 2055 hookers are 900$ tax in for the non-ceramic
set... so u can imagine why i'm bying the flowtechs
Old Feb 5, 2006 | 07:06 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will have to buy quality flange and collector gaskets. The stock ones that come with those headers will last for about five minutes. You will also have to get header bolts and will have to drill out the O2 bung. There is about a 99% chance that every flange will be bent. This will prevent them from ever sealing. Your initial "cheap" purchase will bit you in the behind after you spend additonal money (quality gaskets and bolts are not cheap) and time to make them work. I used my Flowtechs for less than 2000 miles before I threw them in the trash. They are garbage and will make you unhappy. I would save up for better headers.
Do a few searches. I have a long thread devoted to my experience with them.
Old Mar 25, 2007 | 10:14 AM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
Re: will t5 & flowtech headers fit ?
Dont buy flowtech headers i have and when my windows are rolled up i smell exhaust that is how bad they lead after 3 sets of collector gaskets. I am thinking of just welding them.
The fitment was horrible also. THe flange holes were too small for the bolts they supplied .
If you do buy them make sure you have a good dremel ready and a welder.
Street Lethal
Apr 30, 2019 12:14 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
Wvcamaro
Sep 4, 2015 08:38 PM
LilHot
Aug 23, 2015 09:36 PM
theurge
Aug 21, 2015 12:46 PM
