Hooker 2055's without A.I.R
Old Feb 5, 2006 | 12:37 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
From looking on summit and going through the headers, it shows the 2055's with all of the smog equipment on it. Is there any way to order them without the AIR tubes on them? Or would that be a whole new header set?
Old Feb 5, 2006 | 02:50 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
The only ones Ive seen are ceramic coated which cost quite a bit more. But other then that I think they all come with the AIR tubes. You can just take them to an exhaust shop and get the tubes cut off and holes welded on them.
Old Feb 5, 2006 | 04:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 2055's have air tubes. Here are mine cut/welded.
JamesC
Old Feb 5, 2006 | 06:08 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
where'd you get that air cleaner decal? looks sharp...
Old Feb 6, 2006 | 05:19 AM
JamesC's Avatar
Tobias, the following link should provide you with the info you need:
https://www.thirdgen.org/techbb2/sho...iter+and+decal
JamesC
Old Feb 6, 2006 | 08:33 PM
Tobias05's Avatar
thanks James, HO brothers unite! ahahaha
Old Feb 6, 2006 | 10:04 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
Re: Hooker 2055's without A.I.R
i thought there was someone out there that modded the headers and coated them too, i thought i read it in an older post but haven't found it. if i wasn't mistaken they also modded one of the rear pipes for spark plug clearance
maybe they were special ordered from jet-hot?
Old Feb 6, 2006 | 10:27 PM
JDubya18's Avatar
Engine: 305 LB9
The part number for the coated ones without the AIR is HOK-2055-1HKR at summit.
Old Feb 7, 2006 | 07:20 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Hooker does not sell the 2055's without smog fittings. You can, however, get them from Jet Hot with ceramic coating and the air tubes welded up. I think it's around $675 with the thirdgen.org member discount.
Old Feb 12, 2006 | 12:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Isnt the 2460's the same as the 2055's but without the AIR tubes?
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
