y-pipes
Old Feb 19, 2006 | 07:40 PM
thrilla135's Avatar
Car: 1987 trans am
Engine: 406
Transmission: th:400
Axle/Gears: 4:88
y-pipes
im turning my 89 firebird into a street legal race car so -so i need to keep a good muffler system but as most people know the y pipes cut off a lot of power-is there anyway i can get this car to run duel pipes or straight pipes without the mufflers dragging the ground or me having to raise the car up a bit
Old Feb 19, 2006 | 07:53 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
use the button ive seen topics on here and you should look under exhaust. i think i saw it there and yes you can run true duel without lifting the car
Old Feb 19, 2006 | 08:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How does a well designed Y-pipe cut off a lot of power?
Old Feb 21, 2006 | 12:23 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
You can always run a nice set of headers and 3 inch Y pipe and exhaust all the way back like most of us around here. Thats the easy way to get that power your looking for without all the hassle of a dual exhaust setup. Some have done it but is it really worth it in a 3rd gen for the street?
Old Feb 21, 2006 | 02:44 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
Hooker ALL THE WAY!!!
Hooker 1 5/8" primaries 2460 headers, Hooker Y-pipe for it 16767HKR ( cut off the 2 1/2" outlet and make it 3", and a Hooker H.O. Catback 16823HKR. Its a simple fix and an awsome exhaust.
Old Feb 21, 2006 | 11:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Hooker ALL THE WAY!!!
Originally posted by Ray102386
Hooker 1 5/8" primaries 2460 headers, Hooker Y-pipe for it 16767HKR ( cut off the 2 1/2" outlet and make it 3", ... Its a simple fix and an awsome exhaust.
For the same money, you can get Hooker 2055's that have a ready-to-go y-pipe. You might want to modify the collectors, perhaps cut off and weld shut the A.I.R. tubes, but that's a lot easier and makes more sense to me than throwing away 50% of a $200 piece.
Old Feb 21, 2006 | 12:45 PM
thrilla135's Avatar
Car: 1987 trans am
Engine: 406
Axle/Gears: 4:88
how much would the 3" pipe slow me down from straight headers-whta ive been doing is taking the muffler off while racing then putting it back on when done and its such a hassle-i dont want to sacrifice much more hten 2 tenths
Old Feb 21, 2006 | 12:56 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
How about using an exhaust cutout, MRG-5424, at summit...$46.88. Would definately be more convenient than removing the muffler all the time.
Old Feb 21, 2006 | 01:01 PM
five7kid's Avatar
Okay, there's an entire forum dedicated to discussion of exhaust systems. Let's move this over there - and while you're at it, why not do a on these things on that forum? You'll most likely find that everything you're asking has already been asked, discussed, done, and documented.
In particular, I'd suggest you search for a thread started by mw66nova regarding his dual exhaust using longtube Hedman hedders and some inexpensive piping & mufflers - produced a very streetable (although not emissions-legal) system with great power capability; and a thread (forget who started it) regarding pictures of single exhaust systems.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
