3" y-pipe question
Old Mar 4, 2006 | 09:31 PM
1991 RS 305's Avatar
3" y-pipe question
So I want a 3" y-pipe, and through all my searches my two main options are getting the 2055's and cutting off the air tubes and welding on the O2 plug, or get the 2460's with the y-pipe they make for them. Problem with the 2460's is that I would have to cut it up and weld on 3" tubing. Do I have any other options? I can't afford the SLP's, unless I wait a few months. Problem there is that I put Vortecs, cam, intake on my 305 and I really hate to run the stock TBI crap on it unless I have to, spring is only a month away!! Are Y-pipes easy for exhaust shops to fab, or is that more of a specialized thing? Any other opinion's appreciated! Cat back is random 3" if it matters.
Thanks, Matt
Old Mar 5, 2006 | 01:34 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Get the opinions of locals on where to go . The SLP y pipe is small too. But I am sure there is a reason for it .
Sounds like you got the others figured out
Happy modding !
Old Mar 5, 2006 | 04:07 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I have the SLP 3005C Headers and Y-Pipe. Headers are 1.75" Primaries. Y-Pipe is 3" on all 3 sides.
Old Mar 5, 2006 | 09:47 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Are the slp y pipes true 3 inch? As far as I heard 3 inch pipe wont fit between the k member and oil pan.
Old Mar 12, 2006 | 03:19 AM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
i have a custom y, 2 1/2" off left header to 3" at right header, 3" all the way back, soon to be 4", and it seems to work fine
Old Mar 12, 2006 | 10:50 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The SLP 1 3/4 inch headers have a 2 1/2" collector. I don't care for that in the least. It should be a 3" collector.
You can get the "Y" itself from Flowmaster. They make a nice one. Then have the local shop fabricate up the rest. That's what have done and will do on my next go around.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
downsouthboy
Aug 29, 2015 11:29 AM
Out-Cast
Aug 22, 2015 07:49 PM
redmaroz
Aug 16, 2015 11:40 PM
