very irritating noise
Old Mar 11, 2006 | 06:12 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Dude I have some irritating ***noise coming from the cat. Its like a serious serious rattleing coming from the cat when the car warms up in the morning and when I stop the car. You cant here it when the car accelerates but it is embarasing when I stop. However, The check engine light is not on. I was wondering did something come lose in there and if so, do I need to just go ahead and buy a new cat? What is this noise Im hearing guys?
Old Mar 11, 2006 | 09:42 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
its the catalysts in the cat that have been busted loose, my cat does the same thing at idle (when i can get the thing to go back to idleing right ) to me it sounds like a hot cam in the car.. until you realize its the cat
irocyourpants's Avatar
Car: iroc
well if its the stock cat which it most likely is then the inner lining has probably begun to deteriorate
i would recommend replacing the cat or cats (if dual cats) immediately to avoid further damage such as the debris from the old cat reaching the muffler and causing even more "fun" noises
that happened to me and well, it sucks..........
Old Mar 12, 2006 | 04:29 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Both of you are probaly wrong. Check your AIR tube line to see if its bouncing off the exhaust pipe near the cat. Mines been doing it for a year now because I am just to lazy to remove the AIR tube from behind the engine.
Mine also only dose it while ideling in certian temps. and at certain RPMs.
Old Mar 12, 2006 | 03:07 PM
Car: iroc
well i may be wrong but you may be also
i was going to diagnose it as just that but I also had that same problem with the AIR tube boucing around but it only happened when i would accelerate from a stop
Old Mar 13, 2006 | 02:35 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
They may not be wrong at all. Go down and hit your cat with a hammer or similar hard object. If it's deteriorated inside, you'll hear the pieces jumbling about. This typically happens with age.
It could also be a broken hanger or the AIR tube as mentioned. A quick inspection should tell you which.
Old Mar 14, 2006 | 11:58 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Exactly where is the Air Tube located? What Is it near so that I may identify it?
Old Mar 14, 2006 | 12:08 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
its on the other side of the cat heading up to the engine bay, its the only other pipe right near the exaust (its a thin pipe)
Old Mar 14, 2006 | 12:39 PM
Car: '72 Chevy Nova
Transmission: TH350
correct. It's attached to the cat and heads up into the engine bay connecting to the rest of the smog system.
db057
Jan 10, 2020 08:55 PM
86maro_252
Oct 10, 2015 06:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
