Burning boots
Old Mar 25, 2006 | 01:32 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Burning boots
What I got?
-Hooker Long Tubes
-Vortec Heads
-Accel SHORTIES
-MSD 8.5mm wires
The problem?
I've burned 2 spark plug wire boots already on the #7 cylinder. What can be done about this? I've tried everything! Heatshrink, header wrap, etc... There was about 1/8" between the plug boot and header. This gap was not big enough. Is their a better set of plugs I can buy? Again, what can be done?
PS: Taylor boot protectors do not fit!
Old Mar 27, 2006 | 07:44 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Originally Posted by Dirtbik3r
What I got?
-Hooker Long Tubes
-Vortec Heads
-Accel SHORTIES
-MSD 8.5mm wires
The problem?
I'm using the DEI boots: http://store.summitracing.com/partde...5&autoview=sku
probably similar to the Taylors?
You can also buy a complete set of Jacobs ceramic boot wires if you have
the coin, and just use one on #7 and keep the rest of the set as spares?
http://store.summitracing.com/defaul...=egnsearch.asp
(or get just the Jacobs boots, or a 4 or 6 cyl set)
Old Mar 28, 2006 | 10:20 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
advance and autozone sell boots as well. They will work fine. I went to my local speed shop and grabbed a set of 8 and no problems since.
Old Mar 28, 2006 | 10:40 AM
85MikeTPI's Avatar
He said boots don't fit, probably because of the larger boot size of the MSD wires..
Reminded me though, I had NAPA boots before, and I cut the hog ring out of them
and just drapped them down over the large boots.. Worked fine. The DEIs are
quite stiffer than the NAPA boots, and I had a tough time massaging them over
my Accel 300+ boots, which are smaller than the MSDs.
Old Mar 28, 2006 | 11:18 AM
Car: 1991 Z28
Engine: SBC
wow i need to learn to read heh sorry bout that. I think i know what you mean. When i first got my car it had msd wires on it and they were trashed. Looked like the guy had wire tied the wires to parts of the car to pull them away from the header. I just went out and bought taylor wires, custom cut kind. About 20$ cheaper and they fit awesome if they are done right. And the boot protectors fit on them.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Drone358
Sep 28, 2015 04:55 PM
CatmanFS
Sep 19, 2015 09:00 AM
BOOT77
Sep 5, 2015 03:55 PM
