that big block sound
Old Mar 25, 2006 | 01:45 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
i wasn't to sure were to post this.
is there a way to get that big block musel car sound out of a 5.7L 350 tpi?
any cam/exhaust combo's recomended?
but i dont want the fuel economy to suffer greatly
carter
Old Mar 25, 2006 | 02:36 PM
townes19's Avatar
hmmm maybe get higher compression pistons and a cam. other than that, i think your **** out of luck if you dont have a big block.
Old Mar 25, 2006 | 02:44 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
10.5to 1 comp and solid lifters should help
Old Mar 25, 2006 | 04:02 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
get a big ****in cam with straight pipes and you'll be a little closer. but the only way to get the sound of cubic inches is to.... well, get them.
Old Mar 25, 2006 | 04:16 PM
Engine: 305 V8
Transmission: auto
turbos wont help eh?, anyways
Old Mar 25, 2006 | 04:32 PM
Engine: 305 V8
Transmission: auto
like this:
but how much would the LT4 Hot Cam and Edelbrock Heads effect the gas mileage?
https://www.thirdgen.org/newdesign/sounds/mike89gta/lt4hotcam.wav
this ones one of my fav
Old Mar 25, 2006 | 04:38 PM
Car: '72 Chevy Nova
Transmission: TH350
Meh that's not a big block, that's a 218/228 cammed small block that sounds like it's running straight pipes
Your MPG is going to depend on how you drive. If you drive the same, it won't change more than 1-2 mpg.
Old Mar 25, 2006 | 04:48 PM
Engine: 305 V8
Transmission: auto
i know its not a BB, i said i like the sound of it, it sounds kinda simmilar
Old Mar 26, 2006 | 01:04 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Get rid of your single exhaust. Dual exhaust with a crossover will ALWAYS sound best. Keep the pipe length short and run little to no pipe after the mufflers.
Old Mar 26, 2006 | 01:35 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Originally Posted by CarterCarbureto
like this:
eww...that sounds horrible at idle...
Old Mar 26, 2006 | 05:12 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
now this is big block my 70 chevelle ss 454
Click here to watch my-1970-chevelle-ss-454
Old Mar 26, 2006 | 07:48 PM
Engine: 305 V8
Transmission: auto
Old Mar 27, 2006 | 12:35 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
Old Mar 27, 2006 | 01:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i agree.. go true duals with some kind of single chambered muffler like a spintech or single chambered flowmaster. or go dynomax bullet or chambered tube muffler like sweet thunder or such.
dumps after the mufflers...that will get u a deep bassy idle like those big block cars
higher compression and big duration cam will help also. gas mileage will suffer some.. stock L98's are like 18 mpg daily driving with abit of spirit. thats where mine is. highway its more like 23-24. a good heads cammed combo should make 13-15mpg. not bad but not great either. good tuned combos will do 15-17 daily driving.
heres evilcartmens car
http://nvlsonline.org/camarosite/video/ecz28camaro.mp3
forget the specs but its a 294 advertised duration cam... its got a mean racey idle
i have heard 87 TA's car. it has a built 406 with miniram and big solid roller cam. on 150shot it has gone 10.09 at 132. it has a nice deep tone to it.
Old Mar 28, 2006 | 02:01 AM
Engine: 305 V8
Transmission: auto
is Cartman running with a TPI or a carb?
I'll try to get a quick vid of my car today
Old Mar 28, 2006 | 10:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
his is carbed.. hopefully he'll chime in.. his car was running low low 12's and should be 11's this year with his new exhaust.. true duals 3 inch all out
Old Mar 28, 2006 | 01:00 PM
Engine: 305 V8
Transmission: auto
would a car with the same specs but with TPI sound the same??????
Old Mar 28, 2006 | 01:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
IMHO carbs sounds lightyears better then FI, hands down. Carbs lend themselves more to the rumble, and I associate that with larger cubes. I've heard decently large engines with good exhaust, and they sound too smooth, like a engine. Not my flavor.
Old Mar 28, 2006 | 06:32 PM
Engine: 305 V8
Transmission: auto
lol i kinda fidgured that. anyways, I wont be able to get a vid of my car online my camera's to old, my comp wont read it lol
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Cameeeero
Aug 20, 2015 03:06 AM
sreZ28
Aug 14, 2015 07:48 PM
