9-inch rearend exhaust clearance issues
Old Mar 26, 2006 | 12:35 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
What are you guys with 9-inch rearends doing about exhaust? I didn't realize clearance was going to be a problem until I bolted the housing and case into the car today. The u-joint saddle is right against my Flowmaster 3" exhaust.
Attached Thumbnails 9-inch rearend exhaust clearance issues-1clearanceissue.jpg
Old Mar 27, 2006 | 07:31 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Are you sure that pic is with the rearend supporting the weight of the car?
I had a 9" in my car for a few months and my exh would hit in the same
way with the car supported by jackstands on the sub-frames.. With the
suspension loaded, the rear sits up higher in the frame and had a good 1.5"
clearance with the exh..
mike
Old Mar 28, 2006 | 01:51 AM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
this may work
I don't have quite the same set up as you, but this is what I did with my 2.5" true duals & stock rear. I ran the pipes under the axle tubes. I don't have any clearance problems. The bottom of the diff. is about the same as the bottom of the pipes. However, it will make it harder to swap out a rear if it's all welded like mine is. I can send pics. if you like.
Street Lethal
Apr 30, 2019 12:14 PM
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
