smog delete pully install problem??
Old Apr 19, 2006 | 11:08 PM
biggunz37's Avatar
Car: 92 camaro rs
Engine: 305 tbi
well i pulled out the smog pump, no real problem there. I ordered the pully from gmpartsdirect.com # 10186167. on the pully it says top with an arrow pointing up, so i assume that means install it that way. it fits however there is quit a bit of free space in the accessory bracket to the right of the new pully. Is this correct?? because everyone says it appears factory after the install of the pully, but there is a space there. i'm not complaining just wondering if everything is ok and this is how everyone's looks. I tried looking for pics on here of others installs but couldn't find any that helped me.
Old Apr 20, 2006 | 12:36 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
It only goes on one way, the pully "wheel" part obviously faces forward...just try to line up the holes...if it absolutely won't fit, then maybe they gave you the A/C delete pully. BTW, it might have been better to poat this in the Tech/General section, but I can see why you thought it should be under exhaust.
Old Apr 20, 2006 | 01:37 PM
biggunz37's Avatar
Car: 92 camaro rs
Engine: 305 tbi
yeah sorry for posting in exhaust i wasn't sure where to put it and it seemed to fit the best here but i guess it should have went in tech. the thing is that it fits in the accessory bracket fine bolts up no problems. however there's about a two or three inch gap roughly in the bracket, from the edge of the new pulley to the inside of the bracket. hope i'm explaining it well enough?? sorry if i'm not. i'm just wondering if everyone has this or if something's wrong??
Old Apr 20, 2006 | 03:07 PM
Car: 1988 SC Camaro
Engine: 305 TBI
well, I'd be interested in seeing a picture of it...do you have a digital camera that you could post a pic on this this?
Old Apr 21, 2006 | 10:55 AM
biggunz37's Avatar
Car: 92 camaro rs
Engine: 305 tbi
i hope you can see what i'm talking about now, it's a pretty clear pic i hope!!??
Old Apr 21, 2006 | 05:37 PM
dab2pds's Avatar
Car: 05 corolla xrs, 05 hayabusa, 91 rs
Engine: 383
Transmission: t56
its on correctly. that is the way mine looks too.
Old Apr 21, 2006 | 08:05 PM
biggunz37's Avatar
Car: 92 camaro rs
Engine: 305 tbi
o good. i mean it fits good i was just concerned cause everyone's post i read said it looked factory. which it kind of does i just wasn't sure if it should have that gap. thanks for the help!
Old Apr 27, 2006 | 07:50 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
You could just get a different belt and run it the way shown in the tech articles without the pulley. Thats what I did and I have no Problems. Just another option.
Old Apr 28, 2006 | 04:44 PM
Superior Being's Avatar
Car: 88 Camaro
Engine: 305 (stock)
smog delete
While on the topic. I've been thinking about taking my pump out of my 88 305 tbi, but have heard mixed things about it. Is there anything special I need to do other than just take out the pump and put a pulley in there?
Old Apr 28, 2006 | 05:24 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I did it a month ago (same car), there is absolutly no need for a delete pulley. Simply put a smaller belt on (my belt I had on there actually fits perfectly with no squeaking!I think my mechanic jammed a smaller belt on...). Just make sure your remove the correct lines and plug the correct lines as shown in the guide. It looks hard but is quite easy!
Old Apr 28, 2006 | 10:37 PM
Rockstar1's Avatar
I just got a belt a few sizes smaller and it works perfect.
Old May 18, 2006 | 04:11 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
which guide is this?? I'm about to delete my smog stuff.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
