what is the correct hedman LT part# for my application?
Old May 4, 2006 | 06:32 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i have an 87' IROC with the LB9 5speed combo. it is a G92 car with the 3.45 gears. im starting to do minor boltons and was looking at Hedman long tube headers on www.summitracing.com. however, they have a number of part #s that claim to apparently fit my application. my questions are:
1) do the 87' TPI 305 heads have a "D" shaped exhaust port? i know the aluminum Vette heads had this, but i am unsure whether the iron fbody heads had this as well
2) if the header description says it fits heads with angle plugs, will they work ONLY with angle plug heads or are they simply stating theres enough clearance for both angle as well as straight plug setups?
3) if anyone knows, what is the correct hedman part # for my car WITHOUT A.I.R. hookups?
thanks in advance
Old May 6, 2006 | 11:11 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
found all the info i needed. thanks for all your help!
BumpaD82
Feb 26, 2016 02:57 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
WickedBowtie
Sep 11, 2015 11:24 PM
jtwoods4
Sep 3, 2015 10:19 AM
