Edelbrock Cat-back
Old May 7, 2006 | 09:33 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Edelbrock Cat-back
Has anyone installed an Edelbrock 3" cat-back exhaust system and what is the sound level. Did it bolt right on. My 84 Z28 has a four bolt cat flange. Thanks.
Auggie
Old May 9, 2006 | 07:26 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
I have one ...i like it , sound is good .....i am not familiar with your year but it fit well on my 92 ...I think you will be happy GTA...
Old May 9, 2006 | 10:11 PM
Auggie's Avatar
GTA, how's the sound level inside the car at hwy. speeds and did you install it your self. Thanks.
Auggie
Old May 10, 2006 | 12:07 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
I had it installed by a Muff shop...the sound level in the car is fairly quiet....
in fact it is probablly the most quiet of the bunch...there is a slight "drone" but it is slight ... I am in my 30's and i did not want a cop magnet but you can tell that it's not stock either....over all it just sounds good..hope that helps.... GTA
Old May 10, 2006 | 10:33 AM
Auggie's Avatar
Yup, that is just what I am looking for. Thanks a bunch.
Auggie
Old May 13, 2006 | 09:22 AM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
I love how me Edelbrock sounds not to loud but not stock either. Wy only complaint was the fit of it. The pipethat goes from the cat to the pipe that goes over the axle did not fit together very well, i had to do a lot of work on it to get it to fit together. After i got it all installed i brought it to a muffler shop to have it welded, this i recommend because the clamps that come with it do not seem to want to tighten it up enough.
Old May 13, 2006 | 10:06 AM
Auggie's Avatar
90ta, thanks for the info. I will be installing the system myself and will now pre-fit it before I bolt it on. Thanks again.
Auggie
Old May 13, 2006 | 12:02 PM
Car: 1990 trans am
Engine: 350 tpi
Prefitting is a good call, that what i did and how i found out that the fit was not the greatest. I highly recomend the welding, it was only like $30 bucks at a local shop.
Old May 15, 2006 | 11:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Mine fit perfect. Its th eonly mod I havent changed since I bought my car 6 years ago. No rust on it and it still looks great. I have about 35K miles on it.
Old May 19, 2006 | 06:09 PM
ron reece's Avatar
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i have a 89 firebird convertible, 305 tbi, auto car and the 3" cat back is very quiet-can't really tell much difference from stock.
Old May 19, 2006 | 06:13 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Mine fit great until I added sub-frame connectors, but that didn't take much-10 minutes at teh muffler shop.
Sounds great, and even better with my Hooker 2055's!
Old May 24, 2006 | 04:32 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I put that system on my 86 IROC 4 years ago and it's great. Bolted it in out in the front yard with no problems. Tucks up nice and high and you almost can't see the muffler. My next door neighbor has been building hot rods and race cars for years and he's always telling me how much he likes the sound of that IROC when I pull out on the road and push the pedal down. If you have the 4 bolt flange catalytic converter it sounds like you have the 305 HO engine (4 brl. quadrajet carb). The TPI cars had a different convertor flange (2 bolts diagonally across from each other) so be sure you specify the need for the 4 bolt flange connection or you'll have trouble getting it hooked up.
Old May 24, 2006 | 08:09 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Edelbrock changed their mufflers. They now come with the SDT muffler and not the old RPM series muffler.
Old May 24, 2006 | 08:28 PM
firebirdjones's Avatar
Edelbrock cat back
I installed mine on the Iroc myself. Fit was good. I also have Hooker shorty headers with a hooker Y-pipe and I deleted the cat converter as well.
Sound is mild with a very slight drone on the highway, nothing severe in my opinion.
The biggest reason I went with this cat back is because it is the only one I found that had factory style exhaust tips so I could keep the stock look of the car. They came out the back perfect and tuck up nicely, barely visable. I highly recomend it. Goodluck,,,Larry.
Old May 24, 2006 | 10:11 PM
Auggie's Avatar
Thanks for the info everybody. I will be latching onto an Edelbrock cat-back system. Mike, what do you mean SDT??
Auggie
Old May 24, 2006 | 10:59 PM
Their mufflers are totally different now and IMO would sound way different aswell.
vs
Old May 25, 2006 | 09:50 AM
Auggie's Avatar
Hay, thanks for the pic. Looks complacated. Which muffler has the better sound??
Auggie
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
