flowmaster 80 vs. stock
Old May 7, 2006 | 06:02 PM
89GTANYC's Avatar
Car: 89 GTA
Engine: 5.7L V8
hi all, been reading through these boards and searching and been looking for replacement muffler for my 89 GTA without doing a whole catback system. im under the impression that the flowmaster 80 is the easiest install. i just got one question, is the flowmaster 80 noticeably louder than my stock exhaust on my GTA which is fairly loud at the moment? or is there something else under 100 which will provide more dbs. If i have to replace my muffler i just want to get a little extra noise while im at it. thanks in advance for any information you can give me. been listening to some exhuast sounds on the net but most are with headers and such... thanks much
Old May 7, 2006 | 06:46 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
Yea the 80 will definetly make it louder. Its really not all that loud but its a better sound than stock too. It might also have to do with how good re pipes are that your not replaceing. I put an 80 on my car completely stock with thestock I pipe and cat which were both shot, it didnt make it any louder. I went back and bought a new cat and a new i pipe and it definetly got louder after that. It sounded realy good and loud just revin it in park or neutral but driving it sounded better just not all that loud. Its much louder compared to stock at idle, but once you get up in the rpms it just kinda dronned out and wasnt that loud.
If you dont care about keeping dual tailpipes and you just want strait up loud just put in a cherry bomb or dynomax bullet in the stock place with a singe tail or just a turndown at the end of the muffler. Now that will be loud!
Just last week i took off the 80 and stuck a cherry bomb on there with just a turndown so it exits right behind the tire, it's 10x louder than the 80.
* Also if your looking for cheap my cherry bomb was 19.99, the turndown was like 5 bucks and 2 new clamps for 2 dollars each, it took my about and hour to get the flowmaster off and clamp up the new muffler and turndown
Old May 7, 2006 | 07:26 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If you want to keep the dual outlets, I'd say the 80 series is your best bet. You will get a nice increase in sound also. If you don't care about the dual outlets, there are other options that will give you more noise. Such as a Bullet or Flowmaster 40 series.
Old May 7, 2006 | 09:48 PM
89GTANYC's Avatar
Car: 89 GTA
Engine: 5.7L V8
thanks much
thanks so much guys for your info i really really appreciate it!
Old May 11, 2006 | 10:14 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
80 series sound really good. almost a low soothing sound. I have one used if your interested.
Old May 12, 2006 | 06:46 PM
89GTANYC's Avatar
Car: 89 GTA
Engine: 5.7L V8
yah definately interested, i hear they sound better broken in anyways... drop me a line at gtarider718@aol.com, thanks man
Old May 12, 2006 | 07:35 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I had an 80 on one of mine for 9 months...
I hated the droning and resonance.
I actually went back to stock muffler.
With my new 89 I am gonna try magnaflow.
Old May 12, 2006 | 10:07 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Personally I'd go original 40 series and just either put dumps or fabricate the tail pipes
Old May 13, 2006 | 02:54 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
I saw your other post about your 40 series with the duals i know thats why you said that but if someone is just going to dump right after the muffler theres not point using the dual tailpipe muffler just use the single in/single out original 40
Old May 13, 2006 | 03:13 PM
HotRodLarry's Avatar
Car: '83 Z28
On my Z28, the stock exhaust was louder IN the car than the Flowmaster was. You can definately hear the car outside, but inside it is quieter.
Old May 13, 2006 | 04:36 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If you want to do more mods in the future, I'd HIGHLY recommend a full 3" system. You'll be glad later.
No easier than the rest of the decently made catbacks. The thing that makes an easy install, is a proper fit. Most aftermarket catbacks fit just fine.
Flowmaster 80s are, imo, pretty quiet. Flowmaster 40s are a bit louder. There are other aftermarket options that are louder and sound better.
I've heard Flowmaster mufflers are among the worst flowing on the market, if not THE worst. If you've ever seen inside one, you'd know what I mean. There was a test (it's on ls1tech somewhere) that showed a stock 4thgen SS/WS6 muffler flowing MORE than a flowmaster 80s series crossflow. I've never noticed a difference in performance with a flowmaster on any of my vehicles (well, never a GOOD difference anyway)
There are many other alternatives.
Old May 15, 2006 | 12:02 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I have the 80 series on my 84 Trans Am and I am very happy with it. The stock muffler sounded pretty good but with the 80 series you can definitely here the difference. It sounds really good when you wind it up in neutral or get on it from a stoplight. On the highway it just purrs.
Old May 15, 2006 | 12:33 AM
Jacobs454's Avatar
Car: '89 RS
Engine: LT1 350 9C1
I had a 80-series on my '89 RS stocker and it sounded pretty sweet. It didn't sound as good as say a Mustang GT with flowmaster 40's, but then again the Camaro's don't have true duals - YYARRGHH!!! Anyway, before I yanked the old driveline I'd give the FM80 an "A" for effort. It sounded WWAAY better than stock, inside and out. Since I'm a sound-junkie, I actually enjoyed the droning sound way more than the metallic fizzle of the original stock stuffler. As far as performance goes, C'man - it was a stock '89 RS with over 200K and a gutless yeller TBI 305 - it woulda took a MIRACLE to get anything more than a squeek from the rear tire with the hammer down on greased lightnin! BUT, the FM80 didn't slow it down any more than it already was. PLUS, since the FM80's MADE for this car, it already has the dual outlets in the right place. If you go with a 40 series or pretty much any other muffler, you're gonna have a single outlet unless you weld on a dual outlet with two 180-degree bends and an extra 90-degree to get it all the way to the other side of the car. Just a matter of preference, but these cars don't look right with one fat pipe sticking out one side of the car. If that other guy already sold his 80-series or the deal falls through, lemme know 'cause I got the one from my car sitting in the garage collecting cobb-webbs!
Old May 15, 2006 | 04:32 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
well, I've got one on my 91 , and as soon as I get my headers situated it's goin right in the trash and a Borla is goin on. it sounds good till like 3000 rpm, then it just flattens off and sounds like garbage. My 94 crustang with Mac
2 1/2" duals sounds soooooo much better. JMO
Old May 15, 2006 | 04:49 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Does anybody have any opinions on the Edelbrock 3" cat-back system?
Auggie
Old May 15, 2006 | 05:27 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
The flowmaster 80 is meant as a stock/aftermarket replacement. you cant compare it to true duals or 800$ borla systems. its a 40$ muffler and sounds damn good for one. If you run it without tips you cant expect much as far sound goes. But with 3'' angle cut tips mine sounded great at all rpms and i was very satisfied with it. Bedside im giving it to him for 10$ .. lets see anyone get good exhaust sound like this for 10$ LOL
Not a huge fan of edelbrock. I had a complete edel torquer setup and it was the biggest waste of money ever. Considering there headers suck I cant imagine there exhaust are much better .
Last edited by 92rs85berlintta; May 15, 2006 at 05:29 PM. Reason: Automerged Doublepost
Old May 15, 2006 | 06:03 PM
Car: 1988 IROC-Z
Engine: 427 SBC
If you're stock, just get what you think sounds best.
Old May 15, 2006 | 08:54 PM
Car: '72 Chevy Nova
Transmission: TH350
probably the best advice for a stock thirdgen.
Old May 15, 2006 | 09:44 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I would love to know where anyone found Flowmasters 80 series for $40.00...I paid $120 and that was the lowest I found anywhere.
Old May 15, 2006 | 10:10 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Ebay new they cost about 90-100$ on ebay. I was exagerating to make a point. Theres no like comparison for the money$$ is what im saying. he just wants a replacment for stock.
Old May 15, 2006 | 11:30 PM
Car: '72 Chevy Nova
Transmission: TH350
We had one laying around awhile ago I sold for $20 bucks.
I've actually owned 3 of these mufflers, the other two I gave away for free.
Old May 17, 2006 | 05:41 PM
agibby5's Avatar
Car: 1986 IROCZ
Transmission: 700R4 w/ stage 2 shift kit
Same here, except i paid 73.00 three years ago from Jegs. Now they are 79.99 from the same.
Old May 19, 2006 | 01:15 AM
87z28stroker's Avatar
Car: 87 z28 camaro
Engine: 383 stroker
Transmission: 700r4 race re-built
Axle/Gears: 10 bolt stock posi
i got the entire car back kit from summit for my 87 z28 and a new cat...and let me tell you...its got quite a deep rumble on it...i set it up b4 i dropped my 383 in it...and it still was pretty deep at idle, and wen it sup there a reall thick throaty sound, its pretty loud...ive herd the 40s, and other than that im not sure..ive never herd magnaflows...but im pretty happy with mine.....plus...the kit comes with those sweet 3" flowmaster chrome pipes
^^^^ btw...flowmaster series 80....i neglected to tell you what i was talking about
Last edited by 87z28stroker; May 19, 2006 at 01:16 AM. Reason: Automerged Doublepost
Old May 21, 2006 | 03:51 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If you get the 80 Series, I recommend going with the 3" in 2 1/2" out 43083 as it's a smaller and better sounding muffler over the other versions available.
Old May 21, 2006 | 11:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i had the 80 series on my car for 3 years... 3inch in 3inch dual outs. sounded good. not too overally loud but had a nice tone. good idle
now i went powerstick chambered tube.. and its FAR better in sound and flow. i noticed a difference right off the bat. i'd place one of these in the I pipe and fab up twin exits out the back, if you like the tail pipes laying out behind the bumper. thats what i like and what i'll get eventually
Old May 25, 2006 | 01:06 PM
86ttopta's Avatar
I have 80 series on my 86 ta. Sounds good but there are others that sound better and louder.
Old May 25, 2006 | 04:16 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I had an 80 series on my v6 and it sounded terrible. One time I had a guy in a bmw drive by me and yell "get a muffler!" and I was only turning 3k. I'll never do that again. Especially on my ta, which is an automatic.
Vintageracer
Jan 10, 2020 05:33 PM
Genopsyde
Oct 7, 2015 08:35 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Navy8125
Aug 25, 2015 08:25 PM
midias
Aug 22, 2015 01:42 AM
