Engine swap now hedman y-pipe not fitting
Old May 10, 2006 | 11:59 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Okay guys, I (for desperate reasons) had to drop a 1980 305 into my T/A, and I came to find out that the oil pan on a pre-1982 small block has a longer profile, coming almost within an inch of the K member, whereas the 1983 350 I had to pull out had enough room for the y-pipe to my hedman headers...now I have the pan sitting on the y-pipe. I'm thinking about cutting the driver's side pipe off just below the flange, and the passenger side just off the oil pan and splice in with an elbow and piece of pipe...has anyone else encountered this with an older block going in their 3rd gen? And what have you done to correct it? This engine is ready to fire, but need the headers bolted up....thanks for looking and hope to get some replies!
Old May 11, 2006 | 12:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The size and shape of the pan varies with different applications. You can just get another pan that fits.
Old May 11, 2006 | 01:50 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Change the oil pan, its an hour job. Not worth the hackjob exhaust you'd have to do to make it work otherwise.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
