quitest exhuast????
Old May 26, 2006 | 08:15 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
quitest exhuast????
ok so here is my question. what is the quietest muffler out there? i am swapping in an ls1 with a big cam. and i want the thing to be quiet. one because no girl really wants to be in a car that is loud as hell. and second loud is cool but to a point. here is what i am thinking of doing. running true duals for my ls1 and having them dump right before the axle. now i want to have 2 electric cutouts(this is where i will get my loud/obnoxious from) somewhere before the mufflers. so anyone know of any good and quiet mufflers?
Old May 26, 2006 | 08:21 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
For a quiet exhaust you don't want to do turn downs before the axle.Run the full exhaust to the stock locations under the rear bumper.You can still use the cutouts for the track before the mufflers and after the cat.The quietest performance muffler I know are Dynomax SuperTurbos,I believe the stainless Ultraflow is even quieter,and the bonus is the actually are tested to outflow Flowmaster "40" series below 3500RPM.
Old May 26, 2006 | 08:57 PM
irocznickv8's Avatar
Car: 91z28tpil98
Transmission: 700r
the true dual
if u put true duals u r ready making it loud what size pipes u gunna use im usted to making cars louder but ill just revese it what kinda cat do u have 40 flows will be loud but im not sure just goto the site flowmastermufflers.com or something 2-2.5 pipes might be good they have mufflers with rateing on them, bora to
Old May 26, 2006 | 09:14 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
The most quiet V8 car I have ever heard is a 2004 GTO with the LS1. Since you already have an LS1 it would work out for you. No Im jk, but listen to those guys they know alot more about quiet good flowing exhausts than I do
Old May 26, 2006 | 09:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Dynomax Super Turbo Hemi's are one of the quietest (yet good flowing) mufflers I've ever heard. They are big though...
Old May 26, 2006 | 10:01 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Originally Posted by coolram62
The quietest performance muffler I know are Dynomax SuperTurbos.
Old May 26, 2006 | 11:29 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
im going to be running 2.5 from collector back. and sorry no cats. i was almost thinking about getting some stock mufflers off a gto. i have a few friends that are going to be getting exaust soon.
Old May 27, 2006 | 01:49 AM
Car: 91z28tpil98
Transmission: 700r
no cats??? gezz dual and no cats i dunno how to make it quiet
Old May 27, 2006 | 06:47 PM
tad1214's Avatar
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
Have the dynomax super turbos, sounds nice. Is loudish when you get down on it. THe ultra flos are louder, mostly due to the fact they are straight though vs the turbo setup. A turbo muffler will be quiter as it is equal to a muffler much longer then it is (The original idea behind it).
Old May 28, 2006 | 04:45 PM
JPrevost's Avatar
Car: 91 Red Sled
Stock mufflers are very quiet no matter what engine is upstream.
Borla is consider quiet from all platforms but if you're going true duals then you might look at going with a small 2.25" pipe/muffler. Run 2.5" from the engine neck down to a 2.25 or even 2 for the muffler system. Your engine won't hate you running through the smaller exhaust unless you're heavy on the gas. When that happens you should have the exhaust cut-outs open .
Old Jul 10, 2006 | 09:01 PM
91L98Z28's Avatar
Car: Z28
well i guess i'm bringing this one back from the dead but thats ok.
the stock SLP muffler that came on 4thgen LS1's with the performance exhaust system (the "dual dual" system) while heavy is VERY quiet yet freeflowing. most LS1 guys find little to no gain in power when switching from the dual-dual muffler, most often they switch to get louder.
I switched from a flowmaster 80 series over to the SLP and the gain in smoothness and upper rpm pull was noticable.
the only thing i can compare it to is the stock 2004 GTO I've test driven - the GTO is LOUDER on the outside, and about the same volume on the inside.
highly recommended if you want quiet.
92firebirdguy
Sep 1, 2016 07:53 AM
BAK12484
Nov 20, 2001 06:31 PM
redcamaro83
Jul 24, 2001 08:41 PM
87firebird
Apr 22, 2001 06:26 PM
