exhaust sizing question
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
with my engine combo, it should be making around 500hp when its all dialed in, would single 3" be ok or 3.5" be a better route to go?
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Uh, no. Even a 3.5 system will build backpressure.
Besides, you don't want backpressure anyway.
We need to stop beleiving in the old myth.
Car: '02 Z06
Engine: L33 5.7
i know back pressure is bad, and the term i believe people mean to say is scavenging. i just dont know but ill prolly just go with 3.5"
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The 3.5" is all you need for 500HP. Tests have been done at Magnaflow to support this. Like was said above you do not want back pressure. By the way what do those heads flow? What is your dynamic compression ratio?
One more thing get the Magnaflow 3 1/2" muffler. It is of the straight through design and has very little back pressure.
Car: '02 Z06
Engine: L33 5.7
Heads flow around 260cfm @ .500 lift and dynamic compression is about 8.5:1 if i remember correctly, and i already plan to run a straight through borla muffler (XR-1) where the cat would be and still run my spintech out back 3.5" in dual 3" out.
Car: 1989 GTA
Engine: 369 TPI
It will be tough to make 500hp at the crank but it sounds like you have a combination that might do it if built correctly. Trying to get close to that goal myself but with a 355 but that might be a little to much for me.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
