Convert to dual cats
Old Jun 15, 2006 | 12:16 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
My car has the single cat, is it easy to convert to dual? any extra heatshields needed or problem with the rest of my exhaust?
Old Jun 15, 2006 | 12:56 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
why would u want dual cats? just go with a good hi flo cat and then it should work well
Old Jun 15, 2006 | 01:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the dual cat set-up only made 10hp over stock. For the money involved, you might simply consider a high-flow cat and catback.
JamesC
Old Jun 15, 2006 | 08:07 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
To answer your question it is no hard to do. Dyno Don does it all the time at his shop. The more mods you have the more horsepower will get from the mod.
Old Jun 20, 2006 | 12:02 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
So, if I stay with one cat, whats the best one to use? What have people had the best luck with??
Old Jun 20, 2006 | 04:28 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
magnaflow highflow cat
Old Jun 20, 2006 | 04:50 PM
JamesC's Avatar
Catco is another possibility.
JamesC
Old Jun 20, 2006 | 05:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its rated at 10 HP over stock, but that doesnt mean that's what it really is. Which would you rather have, 4 pipes flowing thru 2.5", or 8 pipes flowing thru 3"? Doing the math, two 2.5" has more area than one 3", right? The hardest part about doing the dual-cat conversion is finding the dual-cat AIR pipe, as its discontinued. The other part is the cost. You need to pay a muffler shop to fabricate you a 2.5" mandrel bent y-pipe to go with your 2.5" cats. I second the Magnaflow recommendation.
Old Jun 20, 2006 | 05:27 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Dual cats
Here is how I do them:
(with Magnaflow)
Old Jun 20, 2006 | 05:50 PM
JamesC's Avatar
So what is the real hp gain, 15 or 20? And what would the 3-incher gain? I guess, for me, the real question is cost vs. performance between the the two. I have doubts that the difference would be significant enough to merit the expense--for me personally, at any rate. I'm sure there are others who want every every bit of hp they can muster and who are willing to pay for it. Good for them.
JamesC
Old Jun 20, 2006 | 06:35 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
thats just added wieght
Old Jun 20, 2006 | 08:11 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
seems like if u do that you might as well run true duals.
Old Jun 20, 2006 | 08:53 PM
B Rhodes's Avatar
Car: 91 B4C
I removed my dual cats and put on a random tech single with a slp 3in cat back and definately didnt lose anything performance wise I might have gained but havent g teched it yet for what thats worth.
Hotrodboba400
Dec 10, 2019 07:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
