need ideas to help protect my plug wires ends
Old Jul 2, 2006 | 09:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
Im tired of buying new wires and I need some suggestions for delfecting some of theheat away from the plug boots. I already have those 6" wire protectors on there but its not enough. The worse two wires are the 5 and 7. The number 7 boot is right on the header tube. I am already running accell shorty plugs as well. Im sure that my SLP headers and angle plug heads are not helping either. Would those aluminum plug boots found on the newer Fbodies help at all? also, which wires withstand the most heat? Im running MSD wires now.
Old Jul 2, 2006 | 09:51 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Got pics?
Old Jul 3, 2006 | 09:04 AM
BOTTLEDZ28's Avatar
Transmission: A4
sorry, no pics of my problem. Im gonna try and use those aluminum heat shield found on the newer cars along with the boots and see what happens. My next solution is either new heads and or new headers. OUCH
Old Jul 3, 2006 | 12:41 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Everytime I used MSD wires on my car they burnt up. I used Accel Spiral racing wires, and took some rubber hose, and cut it about 3-4 inches. And then cut it lenght wise so it can slide over my wires. Haven't had a problem in years.
Old Jul 3, 2006 | 03:37 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
MSD Wires
I'm assuming you are using the MSD wires with 90 deg. boots? If not, that's what you need. I'm running them with a set of SLP 1-3/4" headers and stock heads. No problem for me. I've got about 6,000 miles since I installed the headers and wires. I'm also running standard length plugs.
Old Jul 3, 2006 | 03:41 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
https://www.thirdgen.org/forums/exha...lug-wires.html
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Zachattack0925
Aug 12, 2015 09:52 PM
