question about 2055 ypipe and catco 9118
Old Jul 14, 2006 | 11:11 PM
JB22's Avatar
ok, I did a search and it appears that I need to get an expander and expand the end on the cat to fit over the 2055 y-pipe. Is this right? The pipe between the 2 looks to be the identical size. Do they sell a coupler that I could use over the 2 pipes, or is the expander the best way to go on the cat?
Thoughts appreciated
I have a flowmaster american thunder catback #17233 to marry up to the rest on the way, should be here Monday or tuesday
Old Jul 15, 2006 | 06:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No, the 9118 is a perfect fit for the Hooker Y.
JamesC
Old Jul 15, 2006 | 07:13 AM
JB22's Avatar
Hrmm, I'll have to look at it again. I went to put them together last night and it looked like they werent going to fit...
I halted the procedure due to the fact that the y-pipe was about 500 degrees, and I didnt feel like getting torched.
Old Jul 15, 2006 | 07:21 AM
JamesC's Avatar
Always a wise decision .
JamesC
Old Jul 15, 2006 | 04:07 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I had to get a peice of pipe that fit in between the y-pipe and catalytic convertor to make them couple. For some reason, my catalytic convertor did not want to mate to the y-pipe either... despite how many people told me it should just slip right over without a problem.
You can get the peice of pipe from AutoZone for like $3. I believe it is a 3" ID to 3" ID but I can't be sure. It's been so long since I've put the exhaust on the car it's hard to remember.
Old Jul 15, 2006 | 04:12 PM
JamesC's Avatar
Humm, my 9118 slipped over the 2055's without problems.
JamesC
Old Jul 15, 2006 | 10:12 PM
JB22's Avatar
Well, my y-pipe is ceramic coated, so im sure that adds a little to the snug fit.
After some finessing, I did get it on. It just took a little bit.
Old Jul 16, 2006 | 06:12 AM
PontiacV8's Avatar
Car: F-Body / Cadillac STS
Engine: 305 TPI LB9
Transmission: TH 700 R 4
...works fine...Catco9118-Coated Hooker 2055 y-pipe
Old Jul 16, 2006 | 07:35 PM
JB22's Avatar
What did you paint your cat with? Im debating some VHT
Old Oct 22, 2007 | 03:41 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: question about 2055 ypipe and catco 9118
Whatever paint you decide you use to paint the cat, be sure not to spray the inside ot the pipe. It could flake off and clog the honeycomb.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
