Mufflex Ypipe w/ Spohn adj torque arm
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
This has been covered before. Steve Spohn says it will not fit just bolting it on. It will fit if you modify it.
This member modified the frame:
E7
EXHAUST
This one had new pipes mandrel bent:
https://www.thirdgen.org/forums/atta...w-p1270622.jpg
https://www.thirdgen.org/forums/atta...w-p1270624.jpg
I'm planning on getting some other various bends when I do mine.
Here's a pic of it installed on a non-Spohn tq arm. Just for comparison.
https://www.thirdgen.org/forums/atta...-383-19-2-.jpg
E7
EXHAUST
Last edited by fireturd350; Jul 28, 2006 at 07:10 AM. Reason: Automerged Doublepost
Transmission: A4
im in the same dileama. I put my torque arm in the clasifieds. I can see cutting it all up. Ill just make a new crossmember and use either my stock arm or get one that still uses ther stock mounting clamp. thats just the name of the game when it comes to adding all sorts of stuff to our car.
JMatlock88
Jan 13, 2004 01:27 AM
JMatlock88
Feb 28, 2003 01:42 AM
