Will the Hooker 2055 clear the T56 Transmission?
Old Jul 25, 2006 | 12:43 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
That's my question, would they clear the slave cylinder? Also, what type of exhaust are you guys running w/ you're t-56? I'm somewhat on a budget so NO SLP for me.
Zach
Old Jul 26, 2006 | 03:28 PM
BOTTLEDZ28's Avatar
Transmission: A4
they will fit w/o any problem with the T56. Any thirdgen specific header will bolt up w/o a problem if your running the t56. All except longtubes. You can do a search for those issues.
Old Jul 27, 2006 | 11:56 PM
dab2pds's Avatar
Car: 05 corolla xrs, 05 hayabusa, 91 rs
Engine: 383
Transmission: t56
im running hooker 2210 long tubes with the t56. clears it by a mile. 0 clearance issues.
Old Jul 28, 2006 | 10:36 AM
Car: 91 Firebird
Engine: Turbo 355
Will the hedman headers pn 68468 w/ the T56 transmission clear? I need to know as soon as possible. I'm running low on funds.
Zach
Old Aug 1, 2006 | 07:38 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
anyone have a link to a thread highlighting the installation of LT's in a t-5 car?
Old Aug 1, 2006 | 08:10 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
If you are using hooker LT's no problems......the headmans are a diff. story as they are tucked up a little higher than the hookers........ for headman LT's and a T5. that should get you more than enough info. the basics are go from under the car, remove the starter and if you have old motor mounts replace them first befor you go pounding on your headers with a hammer.I had zero problems with my headmans on the passenger side....the driver side well that is another story.........
Good luck,
Mike
Old Aug 2, 2006 | 12:10 PM
Car: 91 Firebird
Engine: Turbo 355
Damn, I was hoping I could run the hedman longtubes w/ the T-56. I guess I will have to get enough money for the hookers.
Zach
angel2794
Sep 8, 2015 06:22 PM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
RyanJB
Sep 2, 2015 01:27 PM
