alright, stock y pipe question
Old Jul 31, 2006 | 01:44 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
alright well it looks like im just gonna buy a new replacement y- pipe for the 82 t/a 305 application for the 350 install in my 82
i need to find out from ya'll about the shape of the very end of the y- pipe at the converter bolt flange down under there
in 82-92 were they all curved just before the flange ?
none were straight back shaped ?
which ones were round pipe and which were the bigger oval shaped
i know the LG4 were smaller and round, in which is what i would want
if any y-pipes undert these cars any years were straight-back shaped just in front of the converter then what years and what engines were they in?
v-8
i ask and need to find out because whatever y pipe i get i will have to hack off the converter flange so i can conect a straigt piece of pipe to the original intermediate exhaust pipe that is under the car still
no converter, was already gone since before i got the car and im not putting one on it
thanks for anything
Old Jul 31, 2006 | 02:09 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I know this answers zero of your questions, but have you checked out the Mac replacement ypipe? The picture does not show that it has the cat flange and it supposedly mates up to the factory manifolds, is mandrel bent, and is true 2.5" head pipes to 3". LINK
Old Jul 31, 2006 | 02:33 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hmm interesting, i like that one alot
i wonder if the very end of that pipe would be paralell with the length of the car installed= straight back*
hmmm
i sent them an email asking about one for an 82 trans am 5.0 i dont know why they list it 86-92 ??
interesting.
thanks
Old Aug 1, 2006 | 12:54 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I have that Y-Pipe on my car, and it's nice! It's bends are exactly stock. The last leg of the pipe angles inward toward the stock cat location. However, the leg before that last bend is parallel to the length of the car. So if you're not running a cat and apparently have a custom-shaped exhaust system, you could cut that pipe off anywhere you want.
As for why it's for '86+, my guess would be because of the slip-fit where it meets the cat. I think some of the earlier years had a flanged connection with the cat. But again, for your application, that wouldn't matter--especially if you cut-off the end anyway.
Old Aug 1, 2006 | 10:50 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
oh!
so 86 and later are not flanged ?!
yes ?
no ?
please confirm
but then at the same token are the 86 up all not straight back at the last leg of the collector of the y pipe ?
what is the leg for that bends towards center of the car for ?
is it to clear suspension a-arm cross or what ?
if i were to hack it off at the last bend so i could put a piece of straight pipe on it would it clear the suspension and everything?
this is what im trying to find out here
so i can get this 350 in this car finally
its killin me over here
i have been trying to find out info like this for months if not longer, to no avail...
if someone had a pic of under neath a car with stock y pipe under it either 82 t- 85,
or 86 up
that would be great...
cuz i am just lost here,
thanks
Old Aug 1, 2006 | 12:50 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i just went up to o reilly auto parts to look up stock y pipes and well 82 is a one year pipe
hum
and then 83 to about 87 is another and then about 88 and up is a third one probably
wth ?
what was different in 82 than 83-up ?
this is getting insane
i ordered the 83 to 87 or so one and gonna check it out in the am
the exhaust book shows only one y pipe for the 82 and the 83-87 one and shows the end of it to be perfectly straight with a very slight slant to it starting at where the left and right pipe are welded to the Y
so i dunno.....
this iss so damn freaking complicated grrrrr i just want a damn y pipe to put on the damn car thats straight pipe outlet
and i need one like yesterday, i need ot get the engine in it finally,i been waiting 6 damn years to get to do this
dammit
pissing me the hell off
i tell ya.....
i realy wish someone knew the shape of the stock 305 y pipes in these cars
seems know one has any idea at all, as if no one has ever been under one and worked on them
but i know better than that because i know every day someone somewhere is removing a damn stock v-8 pipe and putting aftermarket stuff on in place of it
so what is the deal here ?
doesnt anyone know anything about these pipes ?
thanks
Old Aug 1, 2006 | 06:49 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
OK, look at these pics.... it must angle back towards the center of the car in order to clear the floorpan, once it gets close to the drive shaft, it turns backwards and runs parallel to the driveshaft before going over the rear axle.
This is obviously not the stock muffler setup, but the pipes do run in the stock location.
Old Aug 1, 2006 | 09:13 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
slight angle ok neat
so straight back on the oputlet of the y pipe is not good it looks like
although that could really actually be simply corrected by bending the pipe thats going in place of where the converter was
in all reality
so either way it doesnt matter it looks like
just to clear the pass side floor pan
great
i appreciate
im just frustrated and want to get this engine ni and done ASAP like yesterday and if this y pipe thats gona be in the store in the am looks good then the engnie is gonna be sitting in the car by the end of tomorrow i hope
it should, its gonna be alot of freakin work and be 95 degrees out and i gotta move a crap house of junk scrap metal and tear down the shed i built over the car to store it in in oreder to evne be able ot open the door on the car to get it pushed out into the open so i can evne start on it,
junk fridge and trannies and other junk in the way first to relocate to somewhere i dont know where yet and be able to hid out of sight again so the city guy doesnt b#@$!tch
plus i gottapull the engine out of the truck its in right now and thats out in gravel
oh and then thursday its supposed to be rain rain rain all day long..
hum
tomorrow should be fun...
thanks
Old Aug 1, 2006 | 10:37 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
mmmmmm....... rain. You lucky bastard.
Yea, it's all about how that pax side floorpan drops down like that, so they had to angle the exhuast back toward the center.
Have fun!
Old Aug 1, 2006 | 11:03 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
dude man you can have ALL the rain we get here, we have had twice the normal rain here i hate it
i wish it was a drought only rain three times the whole entire summer like it was last summer dammit
i hate all forms of precipitation, but of course ice and snow all winter is the worst
all oyurs man
lol
yeah i think this new pipe coming in the am is gonna be just fine im sure
i ordered it for 83-86 i think it was, but not for 82 i know
so wont know for sure til i go in the am and see it
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
transaero
Aug 31, 2015 01:14 AM
redmaroz
Aug 16, 2015 11:40 PM
