Who has their double hump cross members made?
Old Aug 1, 2006 | 07:29 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I figure this is the board for it since you really only need to make one if you plan on running true duals using longtube headers and want as much clearance as possiable..... mine is almost done, I have to drill one final hole trim down the extra metal and then make up my mind if I should even bother with adding extra metal to my 1/4" thick mount.
so post some pictures and get a good collection going in this thread. and maybe I can get some one to post mine too!
Old Aug 1, 2006 | 08:02 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
I'll be cutting the 4" square tubing (3/16th) tommorow for mine....I'm using it to moddify the stock one and them I'm thinking about using it as a template to build one out of 3/16th flat stock / 3/4" tubing.It should be done by next weekend unless work gets to crazy.
Mike
Old Aug 3, 2006 | 07:09 PM
Engine: ls1, LB9
maybe this will get the ball rolling!
I could have allowed for taller humps but as it is I gained well over 2 1/2" over the stock one. and looking at how I ran my pipes and the original mount this looks like it would work on the 700r4 as well. now I just need to order the J bends and make the pipes.
Old Aug 3, 2006 | 07:17 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
Looks great.......will it clear the fuel lines etc. on the driver side O.K.? Are you going to run it like it is / add more brasing to it?
Old Aug 3, 2006 | 07:44 PM
Engine: ls1, LB9
yep, everything clears great! it is offset toward the passanger side of the car. so it fits just like it came with the car.
I still have not decided on the extra metal. I may throw some triangular chunks at the joints. or add a lip at the front and rear like the original one has. (I guess it depends on how board I am when I pull out the welder again) but then again it is very strong right now
Old Aug 5, 2006 | 03:24 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
After seeing your's I have changed my mind.....I am building one using the 4" square tubing that I have as opposed to modifying one.I'm using some 3" angle for the ends to bolt to the body and cutting some flat pices out of the tube and usind two 4" pices for the "humps" and the passenger side will open all the way to the frame so I can run a smaller bend from my passenger side header.Thanks for the insperation!!!!!
Mike
Old Aug 5, 2006 | 08:30 PM
Engine: ls1, LB9
Mike
cool, I just wish some of the others would post because I know I have seen some real good ones but they are hard to find and many of the photos are no longer in the posts.
Old Aug 5, 2006 | 10:15 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
The only ones I have seen on here have been from t56 and LS1 swaps.I was alos thinking about doing a torque arm relocation mount onto the crossmember I'm sure the 3/16 can handle it hahaha!
Old Aug 6, 2006 | 10:45 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
https://www.thirdgen.org/forums/atta...h-dcp_0016.jpg
https://www.thirdgen.org/forums/atta...h-dcp_0017.jpg
https://www.thirdgen.org/forums/atta...h-dcp_0019.jpg
Old Aug 6, 2006 | 01:25 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
Looks good....simple and to the point.How has it held up?
Thanks,
Mike
Old Aug 6, 2006 | 08:24 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
best x member ive seen.
nice work.
Old Aug 8, 2006 | 09:19 PM
Engine: ls1, LB9
thanks
Old Aug 9, 2006 | 02:15 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I have yet to see that with the humps for the exhaust. That's what i want to do also.
Old Aug 9, 2006 | 11:27 PM
deadbird's Avatar
Engine: TPI 305/ v6
Thanks,
Mike
It only got to see about 1500mi of (moderate/hard) use. No signs of any problems.
The cost was a 4' bar of flat stock and roughly 4 hours of my time. Cheap, simple and effective.
Old Aug 29, 2006 | 08:32 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
Here are some pics. of my progress.I finaly picked up a welder and should have it read over the next few days!!!Let me know what you guys think
Thanks,
Mike
Player detection in Browser...
Old Sep 2, 2006 | 09:14 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
It was dark when I got done welding and painting....sorry......should be done by next weekend!
Old Sep 3, 2006 | 03:00 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
heres mine I used 4" schedule 80 pipe for the "humps" and filleted the ends
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
TreDeClaw
Aug 14, 2015 06:58 PM
