broke a manifold bolt in the head.
Old Aug 13, 2006 | 04:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I decided to install my hooker headers today.
Everything proceeded ok till one bolt broke off flush in the head, then I drilled it and was using an easy-out style bit and that broke off. Any ideas?
This is the left bolt on the #2 cylinder.
Do you think the headers with copper gaskets will hold ok with only 5 bolts on the pass side?
Old Aug 13, 2006 | 04:09 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Mine only has 5 bolts on each side. There is something in the holes and i am going to wait till the crappy paper gaskets blow b4 i redo them.
Old Aug 13, 2006 | 09:39 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
One trick that I use that seems to work very well for removing broken bolts is using a wire/mig welder weld a nut onto the broken bolt.....poor some water on it befor it cools.......then remove.
Good luck,
Mike
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
