Ground clearance problems
Old Aug 27, 2006 | 07:53 PM
92_z28_400_sbc's Avatar
Car: 1992 camaro z28
Engine: 408 c.i. sbc
Transmission: th700r4
Axle/Gears: 3.73 posi.
Hey guys, I've got a 92' camaro z28 and I put a set of hooker super comps on it with 3 inch pipes and I've been having ground clearance issues with my mufflers. I've got flowmaster super 40 mufflers and their 5 inches thick. I like the sound and do not want to get rid of these mufflers. I was wondering if any of you have done this before and if so how you ran your exhaust, where did you put your mufflers, what kind of mufflers did you go with. Any help appreciated, thanks.
Old Aug 27, 2006 | 07:57 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
well where did you put your mufflers?, if you're running true duals chances are you're gonna have ground clearance issues no matter what.
Old Sep 3, 2006 | 10:04 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
I actually had the same problem. However in my case, I hit a raised manhole cover and ripped off one of my 40 Series. My solution was Spintech's 3'' oval tubing and their mufflers. It's only 3'' thick as compared to the 5'' with the Flowmaster. Believe it or not...the Spintechs sound better than the Flowmasters in my opinion.
Old Sep 3, 2006 | 10:54 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I'd say your best bet is to mount your two mufflers horizontally where the original muffler was and just dump behide your wheel. The only way I see getting clearance with duals...
PS thats what I did with my system except its a single 40 horizontal.
GTAman
Mar 15, 2019 11:40 AM
Bryan F
Aug 27, 2015 07:28 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
sreZ28
Aug 14, 2015 07:48 PM
