Edelbrock y pipe, touching stock oil pan
Old Sep 12, 2006 | 06:58 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
I just installed a set of used edelbrock headers, and a y pipe yesterday. The y pipe touches the oil pan, I don't know why this happened. I think I may have overtightened the passenger side of the y pipe. I don't know exactly how much to tighten the bolts, but I tightened them till almost both halves touched, but on the driver side I couldn't tighten them that much, because of alignment issues. I haven't tried a big prybar, to bend it down, I don't have a big enough one. I could unbolt it, and than try something, but where the y pipe seperates, would be nearly impossible for me to take it apart, as it was installled before. I don't think it's a good idea to leave it, as i'm pretty sure it will get the oil too hot. If I had a torch i'd be able to seperate the y pipe, maybe.
Old Sep 14, 2006 | 06:08 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Did you use new gaskets? Maybe try some new ones and not tighten them so much.
Some of the generic oil pans dont have quite as much clearance. as the stocker in this area.
Old Sep 14, 2006 | 07:14 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I'm going to buy more gaskets and try that. It's a kevko pan, but it's supposed to have the same dimensions. If that doesn't work I guess i'll just try bending it. It's going to be a pain, because it was already clamped. thanks
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
