o2 bung , is the the right part ?
Old Sep 25, 2006 | 11:14 AM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
ordering the hedman 68470 headers and matching y-pipe and just wanted to confirm that this is the right O2 bung for the install.
Hedman Weld-In O2 Sensor Bungs: HED-15205 - summitracing.com
do i need one for each side ?? i see from a search that some people weld it into the y-pipe. any advantages / disadvantages to either inastall. on a std manifold set up are there bungs in either manifold ?
any pics would be good.
Old Sep 25, 2006 | 11:59 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I bought a cheap 02 bung, it was like $2 from summit and it works the same. Stock TPI has 1 bung on the drivers side manifolds so that's all you need unless your setup is modified or if you plan on running a wideband. Ideally you'd want your bung closer to the engine, the reading can be less accurate in the y-pipe since the gases cool as they move through the pipes. I have hedman long tubes and the bung is welded in the collector.
Old Sep 25, 2006 | 12:25 PM
Stephen's Avatar
Car: 87 GTA
I guess the question is...Do the threads match?
I have no idea of what the stock threads are though...Sorry.
My suggestion is to by a parts store, and see if you can determine what the threads are on a stock sensor.
Old Sep 25, 2006 | 12:38 PM
fin170703's Avatar
Engine: 350 L98
Wideband
you can tell by my reaction , i run a stock TPI
Okay so i'll place the bung in the header collector on the drivers side. so the only thing i need to find out is the thread type of my std sensor ???
Old Sep 25, 2006 | 12:55 PM
Stephen's Avatar
Car: 87 GTA
With stock TPI, wideband isn't neccessary.
Unless if you are planning on some serious custom chip tuning, wideband isn't needed.
Old Sep 30, 2006 | 01:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
all 02's are 18mm x1.5pitch
Old Sep 30, 2006 | 03:08 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
i bought the ones for my V6 headers at Autozone.. they're just spark plug anti-fowlers with the right threads. Just gotta cut a little off the end and clean out any burrs with the dye grinder. Worked perfect.
Old Oct 1, 2006 | 03:23 AM
fin170703's Avatar
Engine: 350 L98
cheers
i ended up buying the hedman O2 bungs. should have all my parts in 3 weeks , it sucks living in the U.K
LT1Formula
20
Nov 14, 2015 12:02 AM
beast94
Aug 20, 2015 06:44 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
