Quick EGR question
Old Sep 26, 2006 | 09:50 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Quick EGR question
Will removing the EGR valve give me more hp at lower RPM. I heard that all it does is puts exhaust gases into the intake manifold at low RPM and this weakens the throttle response.
Old Sep 26, 2006 | 10:37 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Probably not.
Old Sep 26, 2006 | 09:14 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
EGR is designed to run at part throttle. It's purpose is to introduce inert exhaust gas into the combustion chambers to lower cumbustion temps. This helps reduce the formation of oxides of nitrogen. If the EGR is working properly, you'll not note a gain nor a loss in power. Leave it be; it's not worth the hassle of removing and programming out of the PCM.
Tim sends
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
camaroken83
Aug 10, 2015 11:35 AM
