just put a cat back on my 91 rs camaro
i have a 91 camaro RS, and when i bought it it had a pipe going from the cat about 3 feet back and took a 90 degree curve comming out right before the rear passenger tire. actually it was 2 pipes comming out in front of the tire. Anyways i put a cat-back exhaust on it, ( a cheap one from carquest) with a no name performance muffler, i'm just curious what kind of changes in torque and horse power i'll get any replies would be appreciated. i feel like i cant accelerate as fast but i can pick up faster at higher RMP's
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
none. You might feel something, but for all intensive purposes, nothing. From what you said, looks like you lost a bit of torque and gained a bit of HP. Might all just be mental though. Happens a lot.
If that is all you did, in all honesty you might have gained 5HP at best.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If your new exhaust has mandrel tubing (larger than 2.25") and a free flowing muffler than you did gain power. Although small, it still adds up in the end.
