Header Help!!!! URGENT
Old Sep 28, 2006 | 08:31 PM
marshalljones4's Avatar
91 Camaro 305 TBI........I successfully just removed the Driver side Exhaust manifold. And All but one bolt on the Passanger side exhaust manifold. How the F**K do you get the bolt closest to the Fire wall off? My car is sitting in my garage and i cantmove it lol. There is litrally 3 inches of hard to minipulate your way down to the bolt space. Theres not enough Room for a 3/8 in drive with a medium 14 mm socket. And you sure as heck cant get it with a normal size 14mm wrench. Its just not long enough. Does anybody have any ideas to how to get that bolt off? Do i have to remove the A/C Condenser Big Black box thinggy Atatched to the fire wall? If so, Will i be able to successfully reconect my AC? HELP PLEASE
Old Sep 29, 2006 | 03:14 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
try going from under the car,remove the starter.
Old Oct 7, 2006 | 10:10 PM
superchevy72's Avatar
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
just did this same thing about 2 hours ago. i had to pull up on the front of the manifold to break the bolt loose, then take a wrench from underneath to get it the rest of the way off. actually, i had to alternate between a wrench on the nut itself and pliers on the threaded part of the bolt after it was loose made it a lil easier. once you get it started it comes right off, so dont give up now!!!
Old Oct 7, 2006 | 10:41 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Exactly, attack it at every angle you can. Also, if you have a 1/8" drive with the right socket, use it. I think this is what I ended up doing.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
